[GRASS-user] GDAL libgdal1.6.0.so.1 error (REPOST)
    Santiago Timón
    stimonmail at gmail.com
    Mon Apr 22 04:20:42 PDT 2013
I downloaded the binaries from
http://grass.fbk.eu/grass70/binary/linux/snapshot/ instead of compiling.
Should I try building from code?
Santi
2013/4/22 Markus Metz <markus.metz.giswork at gmail.com>
> On Mon, Apr 22, 2013 at 10:59 AM, Santiago Timón <stimonmail at gmail.com>
> wrote:
> > Hi Markus,
> > I have removed the default ubuntu gdal installation using synaptic.
> > administrador at torrevision:~$ sudo ldconfig -v | grep gdal
> > /home/administrador/gdal192:
> > libgdalconstjni.so.1 -> libgdalconstjni.so
> > libgdal.so.1 -> libgdal.so.1.16.2
> > libgdaljni.so.1 -> libgdaljni.so
> > The symlinks in gdal folder:
> > administrador at torrevision:~/gdal192$ ls -lah | grep ^l
> > lrwxrwxrwx  1 root          root            18 abr 19 11:30
> > lrwxrwxrwx  1 root          root            13 abr 19 11:30
> libgdaljni.so.1
> > -> libgdaljni.so
> > lrwxrwxrwx  1 administrador administrador   17 abr  3 18:32 libgdal.so ->
> > libgdal.so.1.16.2
> > lrwxrwxrwx  1 administrador administrador   17 abr  3 18:32 libgdal.so.1
> > libgdal.so.1.16.2
> > lrwxrwxrwx  1 administrador administrador   19 abr  3 18:32
> libNCSCnet.so ->
> > libNCSCnet.so.0.0.0
> libNCSCnet.so.0
> > -> libNCSCnet.so.0.0.0
> libNCSEcwC.so ->
> > libNCSEcwC.so.0.0.0
> libNCSEcwC.so.0
> > -> libNCSEcwC.so.0.0.0
> > lrwxrwxrwx  1 administrador administrador   18 abr  3 18:32 libNCSEcw.so
> > libNCSEcw.so.0.0.0
> libNCSEcw.so.0
> > -> libNCSEcw.so.0.0.0
> libNCSUtil.so ->
> > libNCSUtil.so.0.0.0
> libNCSUtil.so.0
> > -> libNCSUtil.so.0.0.0
> > lrwxrwxrwx  1 root          root            12 abr 19 11:30
> libogrjni.so.1
> > -> libogrjni.so
> libosrjni.so.1
> > -> libosrjni.so
> That looks good
> > But GRASS still looks for libgdal1.6.0.so.1
> Did you
> make distclean
> configure <custom configure options>
> make
> for GRASS after removing the default ubuntu gdal installation?
> Markus M
> > </INFO>
> > <ERROR timestamp="10:56:35">
> > GDLA error while import. Unable to create input location from input
> > /home/administrador/grass/temp/45ccd92d-daf2-4d80-abc3-a3e14bbc3f4f.tif
> GDAL
> > log:
> /usr/local/grass7.0.svn-x86_64-unknown-linux-gnu-10_11_2012/bin/r.in.gdal:
> > error while loading shared libraries: libgdal1.6.0.so.1: cannot open
> shared
> > object file: No such file or directory
> > </ERROR>
> > Thank you so much for your help,
> > Santi
> >> On Sun, Apr 21, 2013 at 12:42 PM, stimon <stimonmail at gmail.com> wrote:
> >> > ... when I try to launch r.los (via WPS) I get a GDAL related error.
> >> > From the log:
> >> > <ERROR timestamp="11:50:28">
> /home/administrador/grass/temp/ccb06c6f-74ba-4c6d-9d14-16b62b9b9067.tif
> >> > GDAL
> >> > log:
> >> > shared
> >> > </ERROR>
> >> > I have installed GDAL 1.9.2 in ~/gdal192. the LD_LIBRARY_PATH is set:
> >> > administrador at torrevision:~/gdal192$ echo $LD_LIBRARY_PATH
> >> >         libgdal.so.1 -> libgdal1.6.0.so.1
> >> >         libgdal.so.1 -> libgdal.so.1.16.0
> >> There are two links called libgdal.so.1, For gdal 1.9.2 you would need
> >> libgdal.so.1 -> libgdal.so.1.16.2, but you have libgdal.so.1 ->
> >> libgdal.so.1.16.0 which refers to gdal 1.9.0. The first link,
> >> libgdal.so.1 -> libgdal1.6.0.so.1 comes most probably from an older
> >> gdal version that was probably installed system-wide and then only
> >> partially removed. Quite a mess it seems. You could either completely
> >> remove all traces of the old gdal installation or hack Platform.make
> >> to force link to the installation in /home/administrador/gdal192 by
> >> adjusting the gdal link flags.
> >> > Maybe the problem is "libgdal.so.1 -> libgdal1.6.0.so.1" because the
> >> > second
> >> > one it's not present while the first it is, So I also tried to set
> >> > another
> >> > symlink from libgdal1.6.0.so.1:
> >> > libgdal1.6.0.so.1 -> libgdal.so.1
> >> But now you have
> >> and
> >> a circularity.
> >> > -rwxr-xr-x 1 administrador administrador   112705 nov 22 18:10
> >> > libgdalconstjni.so
> >> > -rwxr-xr-x 1 administrador administrador  1312184 nov 22 18:10
> >> > libgdaljni.so
> >> > libgdal.so ->
> >> > libgdal.so.1.16.2
> >> > libgdal.so.1
> >> > -rwxr-xr-x 1 administrador administrador 44048076 nov 22 18:07
> >> > libgdal.so.1.16.2
> >> > -rwxr-xr-x 1 administrador administrador  5078163 nov 26 13:29
> >> > libltidsdk.so
> >> > libNCSCnet.so
> >> > libNCSCnet.so.0 -> libNCSCnet.so.0.0.0
> >> > -rwxr-xr-x 1 administrador administrador   590457 nov 22 14:34
> >> > libNCSCnet.so.0.0.0
> >> > libNCSEcwC.so
> >> > libNCSEcwC.so.0 -> libNCSEcwC.so.0.0.0
> >> > -rwxr-xr-x 1 administrador administrador    81508 nov 22 14:34
> >> > libNCSEcwC.so.0.0.0
> >> > libNCSEcw.so
> >> > libNCSEcw.so.0 -> libNCSEcw.so.0.0.0
> >> > -rwxr-xr-x 1 administrador administrador  8644546 nov 22 14:34
> >> > libNCSEcw.so.0.0.0
> >> > libNCSUtil.so
> >> > libNCSUtil.so.0 -> libNCSUtil.so.0.0.0
> >> > -rwxr-xr-x 1 administrador administrador   713782 nov 22 14:34
> >> > libNCSUtil.so.0.0.0
> >> > -rwxr-xr-x 1 administrador administrador   608641 nov 22 18:10
> >> > libogrjni.so
> >> > libogrjni.so.1 -> libogrjni.so
> >> > -rwxr-xr-x 1 administrador administrador   472066 nov 22 18:10
> >> > libosrjni.so
> >> > libosrjni.so.1 -> libosrjni.so
> >> > I don't know if I am making a mess, but I don't know what else I can
> do.
> >> > I
> >> > have been about 3 hours searching and reading about this lib problem
> >> > without
> >> > sorting it out.
> >> > I have to say GDAL works fine, I installed it to work with AIG rasters
> >> > in
> >> > Geoserver before trying GRASS. However with GRASS I get this error.
> >> > Thank very much for your help.
> >> > Santi
> >> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/GDAL-libgdal1-6-0-so-1-error-REPOST-tp5048562.html
> >> > Sent from the Grass - Users mailing list archive at Nabble.com.
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130422/f20d129f/attachment-0001.html>
