[GRASS-user] Fwd: Re: ppa for grass 7 Ubuntu Quantal
    Rashad M
    mohammedrashadkm at gmail.com
    Mon Apr 22 18:42:17 PDT 2013
I had updated the deian files to be in sync with DebianGIS repo and made
necessary changes for grass70
On Tue, Apr 23, 2013 at 5:59 AM, Hamish <hamish_b at yahoo.com> wrote:
> Hamish wrote:
> > > the first thing that should happen is that the control files
> > > should be updated to pull from the latest from the DebianGIS
> > > git repository.
> Tim:
> > 2 points where this is not always possible:
> > * your repo is at grass (6.4.2-3), we are talking about
> > 6.4.3.x & 7.0.x
> just copy in the debian/ dir from there and locally add a new
> entry for the new version number at the top of the changelog
> file (`dch -v` from the main source dir)
> > * sometimes, there are changes in upstream (in the day to
> > day coding) that do not correspond anymore with the package
> > snapshot taken a a certain point. Thus, you need to disable
> > some patches. If not, you would need to create new patches on
> > nearly daily basis.
> you are right, the patches may be a problem here, but the patches
> are not so many that you'd have to change them very often, maybe
> once every six months. And there is a semi-automatic way to
> update them. (make sure the devscripts package is installed;
> there's a semi-automatic way to do everything in debian
> packaging.., or maybe 4 semi-automatic ways to do everying... :)
> you might try #debian-mentors on the OFTC irc network for
> for definitive advice on the latest trends there.
> Probably between 6.4 and 7svn the patches will need refreshing
> for sure, or disable some of them. For grass7 packages you need
> to make sure that the /usr/bin/grass symlink gets dropped, so
> grass 6 and 7 can be installed on the same system without
> conflicts. (packaged file names must be unique distro-wide)
> > The best would be to have 2 upstream repos in git:
> > * debian files for 6.3.x
> > * debian files for 7.0.x
> We (Frankie, me, DebianGIS,..) talked about that before, the
> result of that discussion was that Debian git repo should be
> for current official packaging efforts, not a sandbox for future
> development. So no experimental branch there for 7 until 7 is
> released and the formal packaging effort begins. But of course
> it's not a big deal in git where things are, you can host that
> at the ppa as you like. But if people want a grass7 binary
> buildbot it'll need some gardening from time to time.
> > LP would then pull these automatically and merge with
> > upstream GRASS source and build the package.
> > This would be really great.
> Right, the 6.4 series can do that already, it's what I'm
> suggesting.
> I do not know if it is possible to just checkout one subdirectory
> from git. So far I haven't been able to do it. (we don't need
> to re-download the entire grass 6.4 source each time from
> DebianGIS)
> > > Instructions are in the src:debian/README.debian file
> > > in the
> > does not exist in
> > git://git.debian.org/git/pkg-grass/grass/debian
> ..the rest of my quote read:
> > > ... in the src:debian/README.debian file in the
> > > GRASS source code
> see
> https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/debian/README.debian
> > > The whole (re)package building exercise should be
> > > possible with a simple 2-10 line script.
> > What for a script are you referring to?
> one that is yet to be written :) just something to download the
> latest rules, apply whatever changes are needed with 'sed -i'
> &/or whatever, then run debuild or whatever the ppa buildbot
> needs to do.
> > What woudl be the purpose?
> to save you lots of wasted effort and time, avoid divergence,
> and avoid human error.
> best,
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130423/b46c5a10/attachment.html>
