[GRASS-user] Fwd: Re: ppa for grass 7 Ubuntu Quantal
Rashad M mohammedrashadkm at gmail.com
Mon Apr 22 19:36:06 PDT 2013
Hi Tim,
could you please test latest build of grass70 package for quantal?
startup error seems to be gone but install extension has some issues
related to g.version script
On Tue, Apr 23, 2013 at 7:12 AM, Rashad M <mohammedrashadkm at gmail.com>wrote:
> Hi,
> I had updated the deian files to be in sync with DebianGIS repo and made
> necessary changes for grass70
> On Tue, Apr 23, 2013 at 5:59 AM, Hamish <hamish_b at yahoo.com> wrote:
>> Hamish wrote:
>> > > the first thing that should happen is that the control files
>> > > should be updated to pull from the latest from the DebianGIS
>> > > git repository.
>> Tim:
>> > 2 points where this is not always possible:
>> > * your repo is at grass (6.4.2-3), we are talking about
>> > 6.4.3.x & 7.0.x
>> just copy in the debian/ dir from there and locally add a new
>> entry for the new version number at the top of the changelog
>> file (`dch -v` from the main source dir)
>> > * sometimes, there are changes in upstream (in the day to
>> > day coding) that do not correspond anymore with the package
>> > snapshot taken a a certain point. Thus, you need to disable
>> > some patches. If not, you would need to create new patches on
>> > nearly daily basis.
>> you are right, the patches may be a problem here, but the patches
>> are not so many that you'd have to change them very often, maybe
>> once every six months. And there is a semi-automatic way to
>> update them. (make sure the devscripts package is installed;
>> there's a semi-automatic way to do everything in debian
>> packaging.., or maybe 4 semi-automatic ways to do everying... :)
>> you might try #debian-mentors on the OFTC irc network for
>> for definitive advice on the latest trends there.
>> Probably between 6.4 and 7svn the patches will need refreshing
>> for sure, or disable some of them. For grass7 packages you need
>> to make sure that the /usr/bin/grass symlink gets dropped, so
>> grass 6 and 7 can be installed on the same system without
>> conflicts. (packaged file names must be unique distro-wide)
>> > The best would be to have 2 upstream repos in git:
>> > * debian files for 6.3.x
>> > * debian files for 7.0.x
>> We (Frankie, me, DebianGIS,..) talked about that before, the
>> result of that discussion was that Debian git repo should be
>> for current official packaging efforts, not a sandbox for future
>> development. So no experimental branch there for 7 until 7 is
>> released and the formal packaging effort begins. But of course
>> it's not a big deal in git where things are, you can host that
>> at the ppa as you like. But if people want a grass7 binary
>> buildbot it'll need some gardening from time to time.
>> > LP would then pull these automatically and merge with
>> > upstream GRASS source and build the package.
>> > This would be really great.
>> Right, the 6.4 series can do that already, it's what I'm
>> suggesting.
>> I do not know if it is possible to just checkout one subdirectory
>> from git. So far I haven't been able to do it. (we don't need
>> to re-download the entire grass 6.4 source each time from
>> DebianGIS)
>> > > Instructions are in the src:debian/README.debian file
>> > > in the
>> > does not exist in
>> > git://git.debian.org/git/pkg-grass/grass/debian
>> ..the rest of my quote read:
>> > > ... in the src:debian/README.debian file in the
>> > > GRASS source code
>> see
>> https://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/debian/README.debian
>> > > The whole (re)package building exercise should be
>> > > possible with a simple 2-10 line script.
>> > What for a script are you referring to?
>> one that is yet to be written :) just something to download the
>> latest rules, apply whatever changes are needed with 'sed -i'
>> &/or whatever, then run debuild or whatever the ppa buildbot
>> needs to do.
>> > What woudl be the purpose?
>> to save you lots of wasted effort and time, avoid divergence,
>> and avoid human error.
>> best,
>> Hamish
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130423/30c10de0/attachment-0001.html>
