[GRASS-user] grass rastercal doesn't work
Eugenio Trumpy frippe12573 at hotmail.com
Tue Apr 23 00:39:01 PDT 2013
Hello Moritz,I Tried just now to redefine the mask, and re-run ther.mapcalc, but I got the sema result:I have the new map but with the same size of the starting one,again seems the mask doesn't work....
Any other hints or test to do?
Regards
E.
> Date: Tue, 23 Apr 2013 09:30:15 +0200
> From: mlennert at club.worldonline.be
> To: frippe12573 at hotmail.com
> CC: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] grass rastercal doesn't work
> On 22/04/13 17:58, Eugenio Trumpy wrote:
> > Thank Moritz,
> > your hint partially solved my problem, because now
> > I got a map, but that is not clipped by the mask.
> > What could be the problem now?
> Difficult to say without more info. Did you redefine your mask after
> changing the region settings ? Have you tried to display MASK to see if
> it is set correctly ?
> Moritz
> > Regards
> > Eugenio
> >  > Date: Mon, 22 Apr 2013 17:44:29 +0200
> >  > On 22/04/13 17:14, Eugenio Trumpy wrote:
> >  > > Hello everybody,
> >  > > I have problems with r.mapcalc
> >  > > I'm use a fresh compiled grass70 from source in my ubuntu desktop 12.10
> >  > > the review cod of grass is 55939.
> >  > > I 'm just trying to clip a raster using a mask:
> >  > > first I created a mask from a raster, then I use r.mapcal:
> >  > > new_cut_map=old_map
> >  > > I got a normal conclusion of calculation with 100% done and the
> >  > > specification [Raster MASK present],
> >  > > but the new raster layer seems to be void.
> >  > > I think I have problems with gdal lib?
> >  > > Have you some hints?
> >  > Check your region settings.
> >  > Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130423/091305e9/attachment.html>
