[GRASS-user] r.sun use - automaticcaly stopped process ?
simogeo
simon.georget at gmail.com
Tue Apr 23 07:19:15 PDT 2013
Hamish : Thanks again for all precision regarding resolutions and RAM use.
All given examples in your last message give me a better idea of what I can
do with my dataset/system config.
The reason, I want the best resolution is that I'm calculating sun
irradiation on buildings (roofs). A 0.2m resolution is ideal. 0.5 can be
accurate enough ... 1m is just acceptable! ;-)
Will try to optimize my treatment by processing my raster file not on the
full extent but on each administrative boundary and then merge them).
Markus Metz-3 wrote
> That's why there is the numpartitions option. Try r.sun
> numpartitions=
> 1>
Indeed, but I'm calculating shadow and /numpartitions/ option does not work
with /-s/ flag (shadow) or /horizon/ option. Thanks anyway.
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-sun-use-automaticcaly-stopped-process-tp5047682p5049139.html
Sent from the Grass - Users mailing list archive at Nabble.com.
