[GRASS-user] Attribute table from v.net.allpairs; v.out.ogr - dsn option in GUI
Markus Metz markus.metz.giswork at gmail.com
Thu Apr 25 02:17:32 PDT 2013
On Thu, Apr 25, 2013 at 10:33 AM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi,
> @Markus M: Thank you for the fix.
> However, somehow I am not able to export the attribute table that is created
> by v.net.allpairs.
> There is nothing special with the v.net.allpairs operation, just 13 points
> along the network. The result
> looks okay and the attribute table is as it should be. When I try db.out.ogr
> nothing is produced (db.out.ogr
> works with other tables):
> db.out.ogr input=map_1 dsn=/home/radinger/Analysis/test format=CSV
> I get the warning above that the vector map <map_1> can not be found and
> there is no output created at
> all. Can anyone reproduce that problem with a net.allpairs-attribute table?
Yes, fixed in r55991. The db.out.ogr module was asking for an input
table and then used that name as vector name, that does not work.
Markus M
> /Johannes
> On Wed, Apr 24, 2013 at 7:30 PM, Markus Metz <markus.metz.giswork at gmail.com>
> wrote:
>> On Wed, Apr 24, 2013 at 3:01 PM, Johannes Radinger
>> > Hi,
>> > There are two little issues that recently popped up in GRASS 7
>> > 1) I performed a pairwise network analysis with v.net.allpairs.
>> > The attribute table to the output map "map" that is produced is called
>> > "map_1" (note: _1 !!).
>> This is because if a table with node attributes exists in the input
>> vector, this table is also copied to the output vector and should have
>> the name map_2.
>> Thus when I then try to export the attribute table to
>> > a csv using v.out.ogr I get following warning (which is of course net a
>> > problem):
>> > db.out.ogr input=map_1 dsn=path/to/csv/file.csv format=CSV
>> > WARNING: Vector map <map_1> not found -->right, because there is no
>> > map_1,
>> > the map is called "map"
>> > Is that an intended behaviour that the corresponding attribute table for
>> > v.net.allpairs gets a ending of "_1"?
>> > 2) It seems that the option for the output in db.out.ogr is maybe set
>> > wrong
>> > (http://svn.osgeo.org/grass/grass/trunk/scripts/db.out.ogr/). Is it
>> > really
>> > necessary that the outputfile already exists because the GUI asks to
>> > select
>> > a file rather than allow specifying the path to the file? I want to
>> > create a
>> > new csv with that module, so maybe the following needs to be changed
>> > from
>> > "old" to "new":
>> > #%option G_OPT_F_INPUT
>> > #% key: dsn
>> > #% gisprompt: old,bin,file
>> > #% description: Table file to be exported or DB connection string
>> > #% required : yes
>> > #%end
>> or simpler
>> #%option G_OPT_F_OUTPUT
>> #% key: dsn
>> #%end
>> Fixed in r55983.
>> Markus M
