[GRASS-user] Attribute table from v.net.allpairs; v.out.ogr - dsn option in GUI
Markus Metz markus.metz.giswork at gmail.com
Thu Apr 25 03:18:41 PDT 2013
On Thu, Apr 25, 2013 at 11:52 AM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi Markus,
> that is working now for me fine!! Thank you.
> Just out of curiousity:
> Could there be the case that there is a table that is not (anymore, yet)
> connected to a vector? In such
> a case it is not possible to export the table as the input is defined by a
> vector map and the layer number?!
db.out.ogr uses internally v.out.ogr which is a bit against the logic
of db.* modules which should work with tables, not vectors.
You can still export any table with either db.select dumping to a text
file or with db.copy, adjusting from_database, from_driver,
from_table, to_database, to_driver, to_table.
Markus M
> /Johannes
> On Thu, Apr 25, 2013 at 11:17 AM, Markus Metz
> <markus.metz.giswork at gmail.com> wrote:
>> On Thu, Apr 25, 2013 at 10:33 AM, Johannes Radinger
>> > Hi,
>> > @Markus M: Thank you for the fix.
>> > However, somehow I am not able to export the attribute table that is
>> > created
>> > by v.net.allpairs.
>> > There is nothing special with the v.net.allpairs operation, just 13
>> > points
>> > along the network. The result
>> > looks okay and the attribute table is as it should be. When I try
>> > db.out.ogr
>> > nothing is produced (db.out.ogr
>> > works with other tables):
>> > db.out.ogr input=map_1 dsn=/home/radinger/Analysis/test format=CSV
>> > I get the warning above that the vector map <map_1> can not be found and
>> > there is no output created at
>> > all. Can anyone reproduce that problem with a net.allpairs-attribute
>> > table?
>> Yes, fixed in r55991. The db.out.ogr module was asking for an input
>> table and then used that name as vector name, that does not work.
>> Markus M
>> > /Johannes
>> > On Wed, Apr 24, 2013 at 7:30 PM, Markus Metz
>> > wrote:
>> >> On Wed, Apr 24, 2013 at 3:01 PM, Johannes Radinger
>> >> > Hi,
>> >> > There are two little issues that recently popped up in GRASS 7
>> >> > 1) I performed a pairwise network analysis with v.net.allpairs.
>> >> > The attribute table to the output map "map" that is produced is
>> >> > called
>> >> > "map_1" (note: _1 !!).
>> >> This is because if a table with node attributes exists in the input
>> >> vector, this table is also copied to the output vector and should have
>> >> the name map_2.
>> >> Thus when I then try to export the attribute table to
>> >> > a csv using v.out.ogr I get following warning (which is of course net
>> >> > a
>> >> > problem):
>> >> > db.out.ogr input=map_1 dsn=path/to/csv/file.csv format=CSV
>> >> > WARNING: Vector map <map_1> not found -->right, because there is no
>> >> > map_1,
>> >> > the map is called "map"
>> >> > Is that an intended behaviour that the corresponding attribute table
>> >> > for
>> >> > v.net.allpairs gets a ending of "_1"?
>> >> > 2) It seems that the option for the output in db.out.ogr is maybe set
>> >> > wrong
>> >> > (http://svn.osgeo.org/grass/grass/trunk/scripts/db.out.ogr/). Is it
>> >> > really
>> >> > necessary that the outputfile already exists because the GUI asks to
>> >> > select
>> >> > a file rather than allow specifying the path to the file? I want to
>> >> > create a
>> >> > new csv with that module, so maybe the following needs to be changed
>> >> > from
>> >> > "old" to "new":
>> >> > #%option G_OPT_F_INPUT
>> >> > #% key: dsn
>> >> > #% gisprompt: old,bin,file
>> >> > #% description: Table file to be exported or DB connection string
>> >> > #% required : yes
>> >> > #%end
>> >> or simpler
>> >> #%option G_OPT_F_OUTPUT
>> >> #% key: dsn
>> >> #%end
>> >> Fixed in r55983.
>> >> Markus M
