[GRASS-user] Attribute table from v.net.allpairs; v.out.ogr - dsn option in GUI
Markus Neteler
neteler at osgeo.org
Fri Apr 26 01:19:11 PDT 2013
On Thu, Apr 25, 2013 at 12:18 PM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> db.out.ogr uses internally v.out.ogr which is a bit against the logic
> of db.* modules which should work with tables, not vectors.
Note: db.out.ogr was born as "quick fix" shell script in GRASS 6.
Given the new possibilities of Python programming in GRASS 7, both
scripts db.out.ogr and db.in.ogr should be rewritten to avoid that the
v.*.ogr modules are called any longer.
markusN
