[GRASS-user] Custom d.vect icons in WX-Python GUI
Casey Vandenberg
casey.vandenberg at sjgeophysics.com
Fri Aug 2 11:43:14 PDT 2013
Hi GRASS-users,
I have a series of custom icons/symbols that I often use when I create
maps or display layers inside of the wx-gui. Older versions of the
d.vect UI would recognize my grass-6.4.x/etc/symbol/CustomDirName
directory and the list of CustomIcons inside of it. With newer
enhancements to the GUI which now displays the icon itself as opposed to
directory/name only, I am no longer able to select any custom icons.
Note: I can still use the command line to display vector layers using a
custom icon (e.g. d.vect map=camp icon=custom/camp)
How can I build my version of GRASS to allow me to choose icons in a
custom symbol directory using the d.vect UI.
I am convinced I have seen documentation on how to do that in the past,
but a couple hours of searching around the wiki today has turned up empty.
Thanks,
Casey
p.s. Here is my Grass Builds System Info if relevant
GRASS version: 6.4.4svn
GRASS SVN Revision: 57320M
GIS Library Revision: 50937 (2012-02-25)
GDAL/OGR: 1.10.0
PROJ4: Rel. 4.9.0, 22 June 2013
Python: 2.7.3
wxPython: 2.8.12.1
Platform: Linux-3.2.0-51-generic-x86_64-with-Ubuntu-12.04-precise
Casey Vandenberg Geomatics Specialist
SJ Geophysics Ltd.
11966 95A Avenue Delta, BC, Canada, V4C 3W2
Office: 604.582.1100
Mobile: 778.928.1103
www.sjgeophysics.com
