[GRASS-user] Filtering high "outliers" in Landsat reflectance imagery?
Sat Aug 3 08:22:15 PDT 2013
Eric Goddard wrote:
> OK, I discovered what was different between my work and home machines.
> The mapcalc if statement doesn't evaluate properly if using
> r.external.out. If r.external isn't used, it evaluates correctly. Bug?
What parameters are you using for r.external.out?
