[GRASS-user] Filtering high "outliers" in Landsat reflectance imagery?
Eric Goddard egoddard1010 at gmail.com
Sat Aug 3 17:59:22 PDT 2013
I tried with tif and img files, same results. I didn't specify any creation
options.
r.external.out directory=/data/GIS/satellite_imagery/shelby_wv2/toar
extension=.TIF format=GTiff
extension=.IMG format=HFA
On Aug 3, 2013 10:22 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Eric Goddard wrote:
> > OK, I discovered what was different between my work and home machines.
> > The mapcalc if statement doesn't evaluate properly if using
> > r.external.out. If r.external isn't used, it evaluates correctly. Bug?
> What parameters are you using for r.external.out?
> Glynn Clements <glynn at gclements.plus.com>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130803/aa662901/attachment.html>
