[GRASS-user] concatenating/combining two table fields for multi-field join
Timmie
timmichelsen at gmx-topmail.de
Tue Aug 6 03:24:20 PDT 2013
> How can I perform the corresponding command on the command for the GRASS
> table?
In
http://grass.osgeo.org/grass65/manuals/sql.html I found:
v.db.update vectormap column=column3 qcolumn="column1 || column2"
running the command on my data yields:
#dbmi: Protocol error
#dbmi: Invalid procedure 107
#ERROR: Fehler beim Ausführen von: 'UPDATE vectormap SET joinkey="a_value
What causes this error and what could I do to prevent it?
