[GRASS-user] concatenating/combining two table fields for multi-field join
Moritz Lennert mlennert at club.worldonline.be
Wed Aug 28 05:44:24 PDT 2013
On 06/08/13 12:24, Timmie wrote:
>> How can I perform the corresponding command on the command for the GRASS
>> table?
> In
> http://grass.osgeo.org/grass65/manuals/sql.html I found:
> v.db.update vectormap column=column3 qcolumn="column1 || column2"
> running the command on my data yields:
> #dbmi: Protocol error
> #dbmi: Invalid procedure 107
> #ERROR: Fehler beim Ausführen von: 'UPDATE vectormap SET joinkey="a_value
> What causes this error and what could I do to prevent it?
Which database backed are you using (dbf, sqlite, postgresql) ? The
manual does state that this command "does not work for DBF driver".
Moritz
