[GRASS-user] Help installing r.stream*
ouspensky ouspensky at gmail.com
Wed Aug 14 18:52:39 PDT 2013
Helmut,
I am new to the GRASS mailing list, how do I keep this thread on the list?
I installed GRASS 6.4.3 stable release. form winGRASS standalone
here is the result:
(Thu Aug 15 09:53:29
2013)
g.extension --verbose extension=r.stream.extract svnurl=
http://svn.osgeo.org/grass/grass-addons/grass6
which: wget: unknown command
Using CURL for downloading data.
WARNING: The GRASS program path: [E:/Programs/Quantum GIS Lisboa/GRASS GIS
6.4.3] contains a space. The build which follows will likely fail.
WARNING: The path to your GIS data: [E:\01-Project\#
KKDL001-YN-2013-LP\04-GIS\05-GRASS] may contain a space. The build which
Fetching <r.stream.extract> from GRASS-Addons SVN (be patient)...
A    r.stream.extract\flag.h
A    r.stream.extract\streams.c
A    r.stream.extract\load.c
A    r.stream.extract\del_streams.c
A    r.stream.extract\local_proto.h
A    r.stream.extract\thin.c
A    r.stream.extract\rbtree.c
A    r.stream.extract\main.c
A    r.stream.extract\close.c
A    r.stream.extract\description.html
A    r.stream.extract\rbtree.h
Compiling <r.stream.extract>...
A    r.stream.extract\flag.c
A    r.stream.extract\Makefile
A    r.stream.extract\do_astar.c
 U   r.stream.extract
Checked out revision 57453.
Makefile:10: E:/Programs/Quantum: No such file or directory
Makefile:10: GIS: No such file or directory
Makefile:10: Lisboa/GRASS: No such file or directory
Makefile:10: 6.4.3/include/Make/Module.make: No such file or
directory
make: *** No rule to make target
`6.4.3/include/Make/Module.make'.  Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
rm: cannot remove directory `E:\\01-Project\\# KKDL001-YN-20
13-LP\\04-GIS\\05-GRASS/Xinjiang/Xinjaing/.tmp/216.0/r.strea
m.extract': Permission denied
(Thu Aug 15 09:53:39 2013) Command finished (10 sec)
what next? rename my folders??
On Thu, Aug 15, 2013 at 6:39 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi,
> >Von: ouspensky
> >An: "Helmut Kudrnovsky"
> please keep it on the grass-user-ML (other can benefit)
> > GRASS version: 6.4.3RC2
> > Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
> see http://grass.osgeo.org/news/28/15/Stable-GRASS-GIS-6-4-3-released/
> > what next?
> please upgrade to stable release and try following in the
> wx-GUI-command-console:
> Helmut
> Gesendet: Mittwoch, 14. August 2013 um 16:37 Uhr
> Von: ouspensky
> Betreff: Re: [GRASS-user] Help installing r.stream*
> Helmut,
>  GRASS version:
> 6.4.3RC2
> GRASS SVN Revision:
> 54341
> GIS Library Revision: 50937
> (2012-02-25)
> GDAL/OGR:
> 1.9.2
> PROJ4: Rel. 4.8.0, 6 March
> 2012
> Python:
> 2.7.2
> wxPython:
> 2.8.12.1
>  when I use the g.extension from command line:
> g.extension -l --verbose extension=r.stream svnurl=
> which: svn: unknown command
> ERROR: svn client required. Please install Subversion first.
>  when i use g.extension from GUI menu:
> g.extension.py[http://g.extension.py] extension=r.stream.extract svnurl=
> http://svn.osgeo.org/grass/grass-addons/grass6[http://svn.osgeo.org/grass/grass-addons/grass6]
> Downloading precompiled GRASS Addons <r.stream.extract>...
> ERROR: GRASS Addons <r.stream.extract> not found
>  what next?
> On Wed, Aug 14, 2013 at 5:41 PM, Helmut Kudrnovsky <hellik at web.de[
> hellik at web.de]> wrote:
>  > running g.extension has no effect.
>  what is the exact issue?
> > It looks like I would have to download and compile them on my system
> > (somehow).
>  no self compiling needed, in winGRASS the addons are precompiled.
> tested here with
> GRASS Version: 6.4.3
> GRASS SVN Revision:
> GIS Library Revision: 50937 (2012-02-25)
> GDAL/OGR: GDAL 1.9.2, released 2012/10/08
> PROJ4: Rel. 4.8.0, 6 March 2012
> Python: 2.7.4
> wxPython: 2.8.12.1
> g.extension -l svnurl=
> Fetching list of modules from GRASS-Addons SVN (be patient)...
> d.anaglyph
> r.stream.angle
> r.stream.basins
> r.stream.del
> r.stream.distance
> r.stream.extract
> r.stream.order
> r.stream.pos
> r.stream.preview
> r.stream.stats
> the precompiled addons are there.
> try on your computer
> svnurl=
> and report back what it says
> >Running GRASS 6.4 on Windows7
>  which version exactly?
> the latest stable is GRASS Version: 6.4.3
> osgeo4w-winGRASS or winGRASS-standalone installer?
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/Help-installing-r-stream-tp5072454p5072458.html[http://osgeo-org.1560.x6.nabble.com/Help-installing-r-stream-tp5072454p5072458.html]
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> grass-user at lists.osgeo.org[grass-user at lists.osgeo.org]
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130815/d2bce2c3/attachment.html>
