[GRASS-user] FW: r.fuzzy.system: specifying raster file?
Johannes Radinger johannesradinger at gmail.com
Mon Aug 19 08:55:13 PDT 2013
Hi Beatrice,
I traced down your problem(s) with your files for r.fuzzy.system. First,
thank you for the minimal examples. That were great for tracing the problem.
So there were three problems:
1) you defined two output levels (res1 and res2) in your .MAP file but you
used different levels in your .RUL file (rul1 and rul2)
2) you did not include the shape factor (e.g. "linear") in the definiton of
your output classes
3) And the real problem that caused all your problems were the line
endings. You're probably working on Windows and the Windows text editor you
used for creating your files have by default a different definition of a
"new line". This is different to Linux line endings. Common simple
texteditors do not show which line endings are in use so it is really
difficult for a user to realize that there are different line endings (I
had the same problems some months/years ago). So what I did: I am using now
TextWrangler on my Mac as text editor of my choice. This program and
probably many others (also for Windows) allow to change the definition of
the line endings to Unix-like "newlines". Just change that and than your
fuzzy system will work smoothly (tested with GRASS6.5 so there is no need
to run r.fuzzy.system in GRASS7)...
/Johannes
On Mon, Aug 19, 2013 at 2:11 PM, Beatrice Christopher Tarimo <
beatrice.tarimo at umb.no> wrote:
>  Dear Johannes,
> I am sorry I could not provide you with feedback as promised in my last
> email. I have been experiencing problems running GRASS 7. I now have it
> running but I have not been able to install extensions/addons. It reports
> an error: "unable to load extensions". I am trying to figure out what I am
> not doing right and will provide you with feedback as soon as I manage to
> test r.fuzzy.system on GRASS 7.
> Thank you.
> With kind regards,
> Beatrice.
> *From:* Beatrice Christopher Tarimo
> *Sent:* 16 August 2013 16:23
> *To:* Johannes Radinger
> *Subject:* RE: FW: [GRASS-user] r.fuzzy.system: specifying raster file?
>   Hi Johannes,
> Thank you for your email and this information.
> I have been running GRASS 6.4.2 and GRASS 6.4.3RC2. I will try with GRASS
> 7.0 and will provide you with feedback as soon as possible, hopefully
> before next week.
> Thank you very much for your help.
> Best regards,
> Beatrice.
> *From:* Johannes Radinger [johannesradinger at gmail.com]
> *Sent:* 16 August 2013 15:20
> *To:* Beatrice Christopher Tarimo
> *Subject:* Re: FW: [GRASS-user] r.fuzzy.system: specifying raster file?
>   Hi again...
>  which version of GRASS are you using at the moment? I know that I had
> some problems with the 6.X version, thus all my work is done with GRASS
> 7.0. So maybe you can try it with GRASS 7.0 and see if that already solves
> your problem.
>  Anyway I can have a look at your minimal example you provided next week
> on my GRASS 7 machine.
>  Best regards,
> Johannes
> On Fri, Aug 16, 2013 at 11:12 AM, Johannes Radinger <
> johannesradinger at gmail.com> wrote:
>> As my server with GRASS is down at the moment I can't check your example.
>> Hopefully I can manage it by next week. I hope thats not too late.
>>  Best regards,
>> Johannes
>> On Fri, Aug 16, 2013 at 10:34 AM, Beatrice Christopher Tarimo <
>>>  Dear Johannes,
>>> I am sorry for any inconvenience this email might cause but I wish to
>>> ask if you managed to have some time to look into the error with regards to
>>> r.fuzzy.system as per our previous communication.
>>> Thank you,
>>> Beatrice.
>>> *Sent:* 31 July 2013 22:10
>>>    Hi Johannes,
>>> Thank you for your email. Please allow me to wait until around this date.
>>> Thank you so very much for your help.
>>> Best regards,
>>> Beatrice.
>>> *Sent:* 31 July 2013 14:44
>>>   Thank you Beatrice for your working example. At the moment I have no
>>> time for testing my self and will be away for a conference next week. So
>>> most probably I can look into your data earliest on the 12 of august. If
>>> you your request is more urgent you can try to post the working example for
>>> the NC dataset to the GRASS user mailing list. Maybe someone else has also
>>> experience with r.fuzzy and can try your example.
>>>  best regards
>>> Johannes
>>> On Tue, Jul 30, 2013 at 7:59 AM, Beatrice Christopher Tarimo <
>>>>  Hi Johannes,
>>>> The problem still persist. I did work in one mapset with all the input
>>>> maps in this mapset, simple map names and only two input maps. The raster
>>>> maps "B3/B4/B7" were imported by r.in.gdal and "ndii" is an index of these
>>>> other maps computed by r.mapcalc. My .map file is similar to the one I sent
>>>> to you with relevant input map names and fuzzy sets definitions.
>>>> These are the maps in my mapset:
>>>> g.list
>>>> rast
>>>> raster files available in mapset <Landsat>:
>>>> B3   B4   B7   ndii
>>>> (Mon Jul 29 23:25:45 2013) Command finished (0 sec)
>>>> Error message from r.fuzzy.system:
>>>> Illegal filename. Character <
>>>> > not allowed.
>>>>  ERROR: Raster map <B4
>>>> > not found
>>>> Same error message for a different input map
>>>> > not allowed.
>>>>  ERROR: Raster map <ndii
>>>> > not found
>>>> I am attaching very simplified .map and .rul files that use GRASS North
>>>> Carolina dataset in the landsat mapset. I use file names as they are here
>>>> but I tried with simple map names and got the same error message.
>>>> r.fuzzy.system
>>>> maps=D:\Beatrice\GRASS\grassdata\nc_spm_08\landsat\Maps.map.txt
>>>> rules=D:\Beatrice\GRASS\grassdata\nc_spm_08\landsat\Rules.rul.txt
>>>> family=Zadeh imp=minimum res=100 output=test1
>>>> > not allowed.
>>>>  ERROR: Raster map <lsat5_1987_40
>>>> > not found
>>>> Thank you very much for your help,
>>>> Best regards,
>>>> Beatrice.
>>>> *Sent:* 29 July 2013 09:15
>>>>    Hi,
>>>>  thank you for the information. From a first view, I don't see any
>>>> major errors in you files.
>>>>  However, to trace your problem I'd suggest to work only in one mapset
>>>> and have all maps that are specified in the map-file in that mapset. Than
>>>> you can also skip the trailing "@PERMANENT". Furthermore I'd suggest to use
>>>> only three or even only two maps for testing your fuzzy-approach and maybe
>>>> rename the maps for the testing to very simple names without any special
>>>> characters (e.g. "test1", "test2"). Maybe this already indicates where the
>>>> error is located.
>>>> Otherwise you could also try to create a minimum test example with one
>>>> of the standard locations (e.g. the GRASS North carlolina dataset) to see
>>>> if the problem also occurs there (which might than be a problem with the
>>>> module itsel). Such an minimum testing example can also be useful for other
>>>> GRASS users to reproduce the error and help tracing the problem.
>>>> So overall, my tip is to simplify your fuzzy procedure stepwise to
>>>> better identify your problem.
>>>>  Best regards,
>>>> Johannes
>>>> On Sun, Jul 28, 2013 at 10:04 PM, Beatrice Christopher Tarimo <
>>>>>  Hi Johannes,
>>>>> Thank you very much for your reply. Please find attached my .map file.
>>>>> Below is the result of g.list of my mapset:
>>>>> (Sun Jul 28 21:33:34
>>>>> 2013)
>>>>> g.list
>>>>> rast
>>>>> raster files available in mapset <user1>:
>>>>> diff            ndii            ndii2_abs       ndii3           sum
>>>>> index           ndii2           ndii2asciirast  ndvi2
>>>>> raster files available in mapset <PERMANENT>:
>>>>> L5171065_06520110726_B20  L5171065_06520110726_B50  clusters
>>>>> L5171065_06520110726_B30  L5171065_06520110726_B60  ndvi
>>>>> L5171065_06520110726_B40  L5171065_06520110726_B70
>>>>> (Sun Jul 28 21:33:34 2013) Command finished (0 sec)
>>>>> No. I am not working in the PERMANENT mapset but I have some of my
>>>>> data in the PERMANENT mapset. I have tried with data stored in a different
>>>>> mapset, I have also to work in the PERMANENT mapset, I get the same error.
>>>>> I have also tried with mapsets (and datasets) coming with GRASS to check if
>>>>> the problem is my mapsets (or my datasets) but r.fuzzy.system returns the
>>>>> same error.
>>>>> Thank you.
>>>>> Best regards,
>>>>> Beatrice.
>>>>> *Sent:* 26 July 2013 09:12
>>>>> file?
>>>>>    Hi Beatrice,
>>>>>  have you checked if there are any trailing spaces after your map
>>>>> name in the .map file?
>>>>> Maybe you can post the .map file as it is and the result of g.list of
>>>>> your mapset.
>>>>> Are you working in the PERMANENT mapset?
>>>>>  Best regards,
>>>>> Johannes
>>>>> On Thu, Jul 25, 2013 at 9:52 PM, Beatrice Christopher Tarimo <
>>>>>> Dear Johannes Radinger,
>>>>>> I am writing to request your help on the problem explained below with
>>>>>> regards to r.fuzzy.system in GRASS GIS. I posted this on GRASS-user forum
>>>>>> and also wrote to the person who wrote the first post on this error but
>>>>>> have not received any replies as yet. Could you please help me?
>>>>>> I am sorry for any inconvenience.
>>>>>> Thank you and best regards,
>>>>>> Beatrice.
>>>>>> ________________________________________
>>>>>> From: neteler.osgeo at gmail.com [neteler.osgeo at gmail.com] on behalf of
>>>>>> Markus Neteler [neteler at osgeo.org]
>>>>>> Sent: 25 July 2013 15:04
>>>>>> To: Beatrice Christopher Tarimo
>>>>>> Subject: Re: [GRASS-user] r.fuzzy.system: specifying raster file?
>>>>>>  Hi Beatrice,
>>>>>> perhaps you could contact Johannes Radinger
>>>>>> (johannesradinger at gmail.com) for this, since he already used the
>>>>>> module.
>>>>>> Please let me then know of manual improvements to be done.
>>>>>> Best
>>>>>> Markus
>>>>>> On Thu, Jul 18, 2013 at 8:56 PM, Beatrice <beatrice.tarimo at umb.no>
>>>>>> wrote:
>>>>>> > Hi,
>>>>>> > I am experiencing a similar problem. I have followed the steps as
>>>>>> in the
>>>>>> > example, making sure all the maps are in the search path but
>>>>>> r.fuzzy.system
>>>>>> > keeps reporting an error regardless of the map specified:
>>>>>> > My input map definition in the .map file:
>>>>>> > %elevation
>>>>>> > $nlow{left; -3,-2; linear; 0; 1}
>>>>>> > $scar{both; -3,-2,0,2; linear; 0; 1}
>>>>>> > $nhigh{right;0,2; linear; 0; 1}
>>>>>> > Reported Error:
>>>>>> > "Illegal filename. Character <
>>>>>> >> not allowed.
>>>>>> > ERROR: Raster map
>>>>>> > <elevation
>>>>>> > not found"
>>>>>> > I have also tried to specify the mapset using "@" as
>>>>>> explained in
>>>>>> > the example, still the same error regardless of the map (and
>>>>>> respective
>>>>>> > mapset)
>>>>>> > %elevation at PERMANENT
>>>>>> > Reported Error:
>>>>>> >> not allowed.
>>>>>> > ERROR: Raster map
>>>>>> > <elevation at PERMANENT
>>>>>> > not found"
>>>>>> > I will be grateful for any advice in finding out the source of this
>>>>>> error
>>>>>> > and how to rectify it.
>>>>>> > Beatrice.
>>>>>> > View this message in context:
>>>>>> http://osgeo-org.1560.x6.nabble.com/r-fuzzy-system-specifying-raster-file-tp5057685p5067435.html
>>>>>>  > Sent from the Grass - Users mailing list archive at Nabble.com.
>>>>>>  > _______________________________________________
>>>>>> > grass-user mailing list
>>>>>> > grass-user at lists.osgeo.org
>>>>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130819/156fef87/attachment-0001.html>
