[GRASS-user] FW: r.fuzzy.system: specifying raster file?
    Markus Neteler
    neteler at osgeo.org
    Mon Aug 19 12:32:35 PDT 2013
On Mon, Aug 19, 2013 at 5:55 PM, Johannes Radinger
<johannesradinger at gmail.com> wrote:
> Hi Beatrice,
> I traced down your problem(s) with your files for r.fuzzy.system. First,
> 3) And the real problem that caused all your problems were the line endings.
> You're probably working on Windows and the Windows text editor you used for
> creating your files have by default a different definition of a "new line".
> This is different to Linux line endings. Common simple texteditors do not
> show which line endings are in use so it is really difficult for a user to
> realize that there are different line endings (I had the same problems some
> months/years ago).
Wild guess: use the function G_getl2()
http://grass.osgeo.org/programming7/getl_8c.html#a4bf86e666fda18059c42b0f5eca6f9bd
"Gets a line of text from a file of any pedigree.
 This routine is like G_getl() but is more portable. It supports text
files created on various
 platforms (UNIX, MacOS9, DOS), i.e. \n (\012), \r (\015), and \r\n
(\015\012) style newlines.
... to import the text file? It is used for example in v.in.ascii/points.c.
(I didn't look at the r.fuzzy.system code if that's feasible)
Markus
