[GRASS-user] v.lidar.edgedetection, v.surf.bspline and visualization issues
Rebecca Bennett
rabennett at ymail.com
Tue Aug 27 06:02:20 PDT 2013
Hello Luis,
I'm about to commit a sacrilegious act on the GRASS-user list but it would seem that Martin Isenburg's LAStools software is more appropriate for this stage of your lidar processing.
http://rapidlasso.com/lastools/
My workflow is to do the tasks you mention below (including the point cloud visualization and DEM generation) in LAStools and then import the DEM / DTM to GRASS for all subsequent processing.
Best,
Rebecca
Rebecca Bennett
Postdoctoral Associate, Wired! Group
Department of Art, Art History and Visual Studies
Duke University, Durham, NC
www.pushingthesensors.com
>________________________________
> From: Luis Ramirez <lu.ramirez.c at gmail.com>
>To: grass-user at lists.osgeo.org
>Sent: Monday, 26 August 2013, 9:03
>Subject: [GRASS-user] v.lidar.edgedetection, v.surf.bspline and visualization issues
>Hi there,
>I´m being working with Grass Gis just for few weeks. I´m trying to
>generate a dsm and dtm from LIDAR data. I imported my data as LAS and i
>was following the steps explained in the Grass Gis Book of neteler and
>mitasova. However, I'am having some problems that are transforming an
>easy task into a time-consuming-nightmare. the first thing that I do not
>understand is why v.lidar.edgedetection works under Grass Gis 6.4. and 7
>instaled in a Virtual machine with Ubuntu but not in Grass Gis 6.4. and
>7 in a windows 7 Computer. after calculating the first two regions (from
>9) it crashes. I tried to increment the parameters "see" and "sen" up to
>the value 10. it is able to calculate a bit more but it still craches.
>after googleing it i Just get information about a bug detected in 2006.
>I would really apreciate to be able to run this module in a windows 7
>computer. do you maybe have a clue?
>the second issue is related to v.surf.bspline. I am using a very small
>map of 1km2 with 118798 points for testing (the goal is to use the
>procedure for a map at least 20 times larger than this one). However,
>Grass Gis 6.4 and 7 (for Ubuntu and For Windows) show me a warning
>message. it says that it could take too long depending on the amount of
>points. I already tried with different values for the parameters" sie"
>and "sin" but it doesnt get any better. I just left the computer
>calculating for few hours but I´m not really getting any result. do
>anyone have an Idea what I´m doing wrong?
>Finally, I´m being trying to get a 3D visualization of the points but
>both the monitors of the GUI and the wxs ended up crashing before I can
>see a thing. is that a known problem? there is any known reason for such
>a problem or even better, a solution or an alternative?
>Thank you in advance!
>Luis
>_______________________________________________
>grass-user mailing list
>http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130827/a8a99946/attachment.html>
