[GRASS-user] removing gaps between areas
Martin Landa landa.martin at gmail.com
Sun Dec 1 22:42:28 PST 2013
2013/11/30 Martin Landa <landa.martin at gmail.com>:
> after patching two vector maps I am getting small gaps between areas
> (see the attached screenshot).
> I found 'rmsa' tool (remove small angles between lines at nodes) of
> `v.clean` as suitable for this task. Unfortunately this tool ignores
> threshold value [1], after a small modification of this tool I can
> remove these gaps using `rmsa` tools. I just wonder if there is a more
> safe or preferable way how to remove gaps.
sorry for the noise - 'rmarea' is the solution, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
