[GRASS-user] removing gaps between areas
Markus Metz
markus.metz.giswork at gmail.com
Sun Dec 1 23:38:35 PST 2013
On Mon, Dec 2, 2013 at 7:42 AM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2013/11/30 Martin Landa <landa.martin at gmail.com>:
>> after patching two vector maps I am getting small gaps between areas
>> (see the attached screenshot).
>> I found 'rmsa' tool (remove small angles between lines at nodes) of
>> `v.clean` as suitable for this task. Unfortunately this tool ignores
>> threshold value [1], after a small modification of this tool I can
>> remove these gaps using `rmsa` tools. I just wonder if there is a more
>> safe or preferable way how to remove gaps.
> sorry for the noise - 'rmarea' is the solution, Martin
You might also try tool=snap with a very small threshold. Which tool
or combination of tools works best to remove gaps depends on the data,
some experimenting can be helpful.
Markus M
