[GRASS-user] digitizer
Vaclav Petras
wenzeslaus at gmail.com
Fri Dec 13 21:14:55 PST 2013
On Fri, Dec 13, 2013 at 6:03 AM, Martin Album Ytre-Eide <
Martin.Album.Ytre-Eide at nrpa.no> wrote:
> Hello all.
> I have been trying the digitizer in 6.4.2, and I am having several
> difficulties. I am working with a polygon map, and as a test, I am trying
> to create a polygon which I try split into four smaller polygons. First I
> divide it in half and then a divide one of the new halves in two.
> Afterwards, I have generated centroids for the area. I have used only the
> "new boundary" tool for this - and that may be wrong? But I have tried some
> other options without any luck.
> Does anyone know how to do this? There also seems to be a problem that the
> map is saved even though I say no thanks. So, if you do a mistake - it
> could be hard to fix - is there an undo function in an other version?
> Hi, I'm not using digitizer regularly, so I cannot answer you first
question. However, there are definitively some improvements in GRASS 7
digitizer including the undo button. I'm not sure about GRASS 6.4.3, so if
nightly build (or what ever) of GRASS 7 is acceptable for you, try it.
> Thanks!
> Martin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131214/f0dc972b/attachment.html>
