[GRASS-user] digitizer
Jón Eiríksson
jeir at hi.is
Sat Dec 14 03:15:09 PST 2013
I don't to have an answer to your problem, but in general, I have found
that the wxgui digitizer in 6.5 works reasonably well, whereas the 6.4.3
does not. The same is true of version 7, it works for me.
Jon
On 14 Dec 2013, at 5:14, Vaclav Petras wrote:
> On Fri, Dec 13, 2013 at 6:03 AM, Martin Album Ytre-Eide <
> Martin.Album.Ytre-Eide at nrpa.no> wrote:
>> Hello all.
>> I have been trying the digitizer in 6.4.2, and I am having several
>> difficulties. I am working with a polygon map, and as a test, I am
>> trying
>> to create a polygon which I try split into four smaller polygons.
>> First I
>> divide it in half and then a divide one of the new halves in two.
>> Afterwards, I have generated centroids for the area. I have used only
>> the
>> "new boundary" tool for this - and that may be wrong? But I have
>> tried some
>> other options without any luck.
>> Does anyone know how to do this? There also seems to be a problem
>> that the
>> map is saved even though I say no thanks. So, if you do a mistake -
>> it
>> could be hard to fix - is there an undo function in an other version?
>> Hi, I'm not using digitizer regularly, so I cannot answer you first
> question. However, there are definitively some improvements in GRASS 7
> digitizer including the undo button. I'm not sure about GRASS 6.4.3,
> so if
> nightly build (or what ever) of GRASS 7 is acceptable for you, try it.
>> Thanks!
>> Martin
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
