[GRASS-user] Cannot change directory via GRASS command console
Helmut Kudrnovsky
hellik at web.de
Sat Dec 14 14:53:48 PST 2013
> I have a bash script located in D:\Users\....\Sattelite_Processing (see my
earlier message) called
> "myscript.sh"
ah it's a shell script, so may you are mixing windows console
commands/syntax and *nix shell commands/syntax?
in windows console commands/syntax to change drive and folder:
e.g.
C:\test\test>cd /D e:\
e:\>
*nix shell commands/syntax (e.g. also emulated by msys in osgeo4w):
e.g.
test at test-HP ~
$ cd /e
test at test-HP /e
have a look for example in
C:\OSGeo4W\apps\grass\grass-6.4.4svn\bin\r.univar.sh.bat
@"%GRASS_SH%" "%GISBASE%/scripts/r.univar.sh" %*
so in your myscript.sh you may use *nix shell commands/syntax and also
double quotes if the path has white space in it.
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-change-directory-via-GRASS-command-console-tp5092923p5094270.html
Sent from the Grass - Users mailing list archive at Nabble.com.
