[GRASS-user] Cannot change directory via GRASS command console
    PB
    pbrewin at fisheries.gov.fk
    Wed Dec 18 05:27:57 PST 2013
Hi - ok so I'm convinced that there is a bug in the grass installation
bundled with qgis.  I can't for the life of me change directory from within
the grass gui command console.  So what I've done is install grass as a
stand alone, which does work as you would expect.  your suggestion of
looking at C:\OSGeo4W\apps\grass\grass-6.4.4svn\bin\r.univar.sh.bat
convinced me - the qgis grass installation doesn't create this path, and I
think something must get confused - r.univar.sh.bat is found here C:\Program
Files\QGIS Dufour\apps\grass\grass-6.4.3\bin under the qgis installation.
Thanks for your help - although we didn't find the problem, the discussion
lead to a solution.
PB
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-change-directory-via-GRASS-command-console-tp5092923p5094900.html
Sent from the Grass - Users mailing list archive at Nabble.com.
