[GRASS-user] Cannot change directory via GRASS command console
Robert Andrew Brown
brown782 at purdue.edu
Wed Dec 18 05:38:49 PST 2013
I am having the same issue removing the GIS lock as well I am using a Mac and have not been able to remove it for months tried reinstalling still not workin.
Sent from my iPhone
> On Dec 18, 2013, at 8:27 AM, PB <pbrewin at fisheries.gov.fk> wrote:
> Hi - ok so I'm convinced that there is a bug in the grass installation
> bundled with qgis. I can't for the life of me change directory from within
> the grass gui command console. So what I've done is install grass as a
> stand alone, which does work as you would expect. your suggestion of
> looking at C:\OSGeo4W\apps\grass\grass-6.4.4svn\bin\r.univar.sh.bat
> convinced me - the qgis grass installation doesn't create this path, and I
> think something must get confused - r.univar.sh.bat is found here C:\Program
> Files\QGIS Dufour\apps\grass\grass-6.4.3\bin under the qgis installation.
> Thanks for your help - although we didn't find the problem, the discussion
> lead to a solution.
> PB
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-change-directory-via-GRASS-command-console-tp5092923p5094900.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
