[GRASS-user] Map display does not open at start
Daniel Victoria
daniel.victoria at gmail.com
Mon Feb 4 06:05:56 PST 2013
I just installed Grass 6.4.3.RC2 from OSGeo4W (win7 here) and when I start
Grass the Layer Manager opens but the GIS Map Display does not show up.
In the command console I see the folowing message:
File "C:\OSGeo4W\apps\grass\grass-6.4.3RC2\etc\wxpython\ma
pdisp\mapwindow.py", line 425, in OnIdle
self.UpdateMap(render = True)
pdisp\mapwindow.py", line 575, in UpdateMap
windres = windres)
File "C:\OSGeo4W\apps\grass\grass-6.4.3RC2\etc\wxpython\co
re\render.py", line 875, in Render
os.environ["GRASS_REGION"] = self.SetRegion(windres)
re\render.py", line 702, in SetRegion
region = self.AdjustRegion()
re\render.py", line 488, in AdjustRegion
self.region["nsres"] = mapheight / self.height
ZeroDivisionError
float division by zero
If I open a new display it works and I can load image used to create the
location.
I've deleted and re-created the location several times but nothing changed.
I've seen some bug reports about this error but did not manage to find a
solution
Here is the output of g.region -p
projection: 1 (UTM)
zone: -23
datum: wgs84
ellipsoid: wgs84
north: 7548415.00000001
south: 7338385
west: 384884.99999999
east: 623415
nsres: 30
ewres: 30
rows: 7001
cols: 7951
cells: 55664951
Cheers
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130204/e0d53e32/attachment.html>
