[GRASS-user] Map display does not open at start
Daniel Victoria
daniel.victoria at gmail.com
Tue Feb 5 03:16:53 PST 2013
An update on the problem. I installed Grass 7.0svn provided by OSGeo4W and
it's working. Just version 6.4.3RC2 that is having trouble opening the Map
Display Window
On Mon, Feb 4, 2013 at 12:05 PM, Daniel Victoria
<daniel.victoria at gmail.com>wrote:
> I just installed Grass 6.4.3.RC2 from OSGeo4W (win7 here) and when I start
> Grass the Layer Manager opens but the GIS Map Display does not show up.
> In the command console I see the folowing message:
> Traceback (most recent call last):
> File "C:\OSGeo4W\apps\grass\grass-6.4.3RC2\etc\wxpython\ma
> pdisp\mapwindow.py", line 425, in OnIdle
> self.UpdateMap(render = True)
> pdisp\mapwindow.py", line 575, in UpdateMap
> windres = windres)
> File "C:\OSGeo4W\apps\grass\grass-6.4.3RC2\etc\wxpython\co
> re\render.py", line 875, in Render
> os.environ["GRASS_REGION"] = self.SetRegion(windres)
> re\render.py", line 702, in SetRegion
> region = self.AdjustRegion()
> re\render.py", line 488, in AdjustRegion
> self.region["nsres"] = mapheight / self.height
> ZeroDivisionError
> float division by zero
> If I open a new display it works and I can load image used to create the
> location.
> I've deleted and re-created the location several times but nothing changed.
> I've seen some bug reports about this error but did not manage to find a
> solution
> Here is the output of g.region -p
> projection: 1 (UTM)
> zone: -23
> datum: wgs84
> ellipsoid: wgs84
> north: 7548415.00000001
> south: 7338385
> west: 384884.99999999
> east: 623415
> nsres: 30
> ewres: 30
> rows: 7001
> cols: 7951
> cells: 55664951
> Cheers
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130205/9fcef553/attachment.html>
