[GRASS-user] wild cards don't work with g.mlist
Hamish
hamish_b at yahoo.com
Wed Feb 6 17:49:25 PST 2013
Jorge wrote:
> I am trying to list (g.mlist) vector maps starting with the
> letter “s” and when I use the wild card * I don’t get any
> results.
> Using the command g.mlist vect gives me a list of all the
> vector maps in my MAPSET’s
Hi are you trying from the command line window or from the wxGUI command console? There are some issues with the wxGUI command console dealing with "quotes", there's an active ticket about it.
From the real command line it should be ok; note the "*" pattern
parameter should be quoted to protect it from the shell interpreter.
Hamish
