[GRASS-user] Map display does not open at start
Daniel Victoria
daniel.victoria at gmail.com
Thu Feb 7 08:09:20 PST 2013
Martin,
You are right. Map display starts but it does not show up anywhere. I can
see it's running on the taskbar and the task manager (attached screenshot
mapdisplay1.png)
Then, when I go to the taskbar and ask for the MapDisplay to be maximized,
the mapdisplay shows up and I can now resize it to whatever size I want.
On Thu, Feb 7, 2013 at 11:45 AM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2013/2/7 Daniel Victoria <daniel.victoria at gmail.com>:
> > The GIS Layer Manager stars but no Map Display. But if I ask for a new
> map
> > display, it open up and I can load rasters.
> are you sure? Probably map display is hidden somewhere. If it doens't
> start you should get some error message (traceback). In GRASS 6.5 when
> map size is invalid, it's using 640x480. So the map display should
> start...
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130207/dd9e499b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130207/dd9e499b/attachment-0001.png>
