[GRASS-user] Global Land Cover Characterization data type
Mauricio Zambrano-Bigiarini
hzambran.newsgroups at gmail.com
Thu Feb 14 04:55:20 PST 2013
2013/2/14 Michael Spencer <michael_spencer at live.co.uk>:
> Hi,
> Has anyone used the USGS Global Land Cover Characterization data available
> here?
> http://edc2.usgs.gov/glcc/globe_int.php
> Indication is that the file format is Erdas Imagine .img, but GRASS is
> coming back with a file type unknown error. Help/readme file suggests data
> is byte type, which leaves me none the wiser!
> Happy for any pointers.
> Ta,
> Michael
Hi Michael,
Some time ago I had the same problem when using R for reading the
files. From the USGS I was told that the problem is the lack of header
(as mentioned in the metadata that I did not read :( )
You need to make a projection header file as per the FAQ at:
http://landcover.usgs.gov/faq.php#three
The details of the LAEA projection to generate the header file can be found on:
http://edc2.usgs.gov/glcc/sadoc2_0.php
IHTH,
Mauricio
Water Resources Unit
Institute for Environment and Sustainability
Joint Research Centre, European Commission
webinfo : http://floods.jrc.ec.europa.eu/
DISCLAIMER:
"The views expressed are purely those of the writer
and may not in any circumstances be regarded as
stating an official position of the European Commission"
Linux user #454569 -- Ubuntu user #17469
"Where ambition ends happiness begins"
(Source Unknown)
http://www.r-project.org/posting-guide.html
