[GRASS-user] i.landsat.toar comments have only 0 value
Daniel Victoria
daniel.victoria at gmail.com
Fri Feb 15 02:58:48 PST 2013
Hi all,
I just ran i.landsat.toar to get the radiance values for a TM5 image and I
noticed that the comments in the output metadata (from r.info) have some
problem.
1) I asked for radiance output but the comments says the image is
reflectance. Image values are consistent with radiance values so I believe
the line in the comments is wrong.
2) Values for earth-sun distance, digital number range etc are all 0.
I'm using OSGeo4W, Grass7svn revision 54962
Bellow is the output from r.info so you can see what I mean
| Layer: rad2005_cor.1 Date: Fri Feb 15 08:38:31
2013 |
| Mapset: PERMANENT Login of Creator:
daniel |
corr_Atm_utm23s |
| DataBase:
C:\grassdata |
| Title: ( rad2005_cor.1
| Timestamp:
none |
| Type of Map: raster Number of Categories:
0 |
| Data Type:
DCELL |
| Rows:
7001 |
| Columns:
7951 |
| Total Cells:
55664951 |
| Projection: UTM (zone
-23) |
| N: 7548415.00000001 S: 7338385 Res:
30 |
| E: 623415 W: 384884.99999999 Res:
30 |
| Range of data: min = 0 max =
194.52 |
| Data
Description: |
| generated by
i.landsat.toar |
Comments: |
| Reflectance of Landsat-5 TM (method
corrected) |
| Acquisition date ......................
2005-05-15 |
| Production date .......................
2012-12-01 |
| Earth-sun distance (d) ................
-0.00000000 |
| Digital number (DN) range ............. 0 to
0 |
| Calibration constants (Lmin to Lmax) .. +0.000 to
+0.000 |
| DN to Radiance (gain and bias) ........ -0.00000 and
+0.00000 |
| Mean solar irradiance (ESUN) ..........
-0.000 |
| Reflectance = Radiance divided by .....
-0.00000 |
| i.landsat.toar -r input_prefix="tm5_2005_orig."
output_prefix="rad20\ |
| 05_cor."
metfile="C:\projetos\agspec\correcao_landsat\LT521807620051\ |
| 35CUB00\LT52180762005135CUB00_MTL.txt" sensor="tm5"
method="correcte\ |
| d" date="2005-05-15" sun_elevation=37.184 product_date="2012-12-01"
| percent=0.01 pixel=1000
rayleigh=0.0 |
Thanks
Daniel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130215/46b659f7/attachment.html>
