[GRASS-user] Global Land Cover Characterization data type
Michael Spencer
michael_spencer at live.co.uk
Fri Feb 15 05:05:47 PST 2013
Got the job done, thanks for all the pointers.
Took location info from the readme file included in download (which is different to the online help). Used a lat-long on wgs84 projection.
Imported via r.in.bin, and again included the details from readme file in bounds tab.
Strikes me usgs made this a lot more difficult that it needed to be!
Thanks again,
Michael
Hi Michael,
http://edc2.usgs.gov/glcc/globdoc2_0.php#dataform
says that data is in binary flat format, no header...
I suppose that if you download in geographical lat long projection, and that you get the header info from:http://edc2.usgs.gov/glcc/globdoc2_0.php#geog
then you should be able to set a new location from this info and import straight in GRASS with one of the generic binary input function (maybe in r.in.gdal, maybe another more specific.
good luck and tell us how it went,Yann
On 14 February 2013 18:02, Michael Spencer <michael_spencer at live.co.uk> wrote:
Has anyone used the USGS Global Land Cover Characterization data available here?
http://edc2.usgs.gov/glcc/globe_int.php
Indication is that the file format is Erdas Imagine .img, but GRASS is coming back with a file type unknown error. Help/readme file suggests data is byte type, which leaves me none the wiser!
Happy for any pointers.
Ta,
Michael
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130215/8bcb5943/attachment.html>
