[GRASS-user] Global Land Cover Characterization data type
    Margherita Di Leo
    diregola at gmail.com
    Fri Feb 15 05:52:40 PST 2013
On Fri, Feb 15, 2013 at 2:05 PM, Michael Spencer <michael_spencer at live.co.uk
> wrote:
>  Got the job done, thanks for all the pointers.
> Took location info from the readme file included in download (which is
> different to the online help). Used a lat-long on wgs84 projection.
> Imported via r.in.bin, and again included the details from readme file in
> bounds tab.
> Strikes me usgs made this a lot more difficult that it needed to be!
Maybe worth to be put in the wiki, could you be so kind?
Thank you!
madi
> Thanks again,
> Michael
> Hi Michael,
> http://edc2.usgs.gov/glcc/globdoc2_0.php#dataform
> says that data is in binary flat format, no header...
> I suppose that if you download in geographical lat long projection, and
> that you get the header info from:
> http://edc2.usgs.gov/glcc/globdoc2_0.php#geog
> then you should be able to set a new location from this info and import
> straight in GRASS with one of the generic binary input function (maybe in
> r.in.gdal, maybe another more specific.
> good luck and tell us how it went,
> Yann
> On 14 February 2013 18:02, Michael Spencer <michael_spencer at live.co.uk>wrote:
>  Hi,
> Has anyone used the USGS Global Land Cover Characterization data available
> here?
> http://edc2.usgs.gov/glcc/globe_int.php
> Indication is that the file format is Erdas Imagine .img, but GRASS is coming
> back with a file type unknown error. Help/readme file suggests data is
> byte type, which leaves me none the wiser!
> Happy for any pointers.
> Ta,
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES). Unit H03 – FRC
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130215/31b9bb68/attachment-0001.html>
