[GRASS-user] Problem in install Extensions from addons
    Rebecca Bennett
    rabennett at ymail.com
    Sun Feb 17 10:09:52 PST 2013
final error message (from terminal ./r.out.kml) didn't come through on last email, sorry.
>________________________________
> From: Rebecca Bennett <rabennett at ymail.com>
>To: Hamish <hamish_b at yahoo.com>; "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
>Sent: Sunday, 17 February 2013, 12:57
>Subject: Re: [GRASS-user] Problem in install Extensions from addons
>Hi Hamish, thanks for your response
>dpkg -l grass
>| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
>|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
>||/ Name           Version
 Description
>ii  grass          6.4.3rc2-2~pre Geographic Resources Analysis Support System
>Checked add-ons menu in gui no sign of r.out.kml, no response from typing command in gui but locate says it's there
>GRASS 6.4.3RC2 (Deer_park):~ > locate r.out.kml
>/home/becca/.grass6/addons/bin/docs/html/r.out.kml.html
>/home/becca/.grass6/addons/bin/scripts/r.out.kml
>/home/becca/.grass6/addons/docs/html/r.out.kml.html
>/home/becca/.grass6/addons/scripts/r.out.kml
>so I tried moving to the /home/becca/.grass6/addons/scripts/ and running (./r.out.kml) getting this message:
>so close... :)
>> From: Hamish <hamish_b at yahoo.com>
>>To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>; Rebecca Bennett <rabennett at ymail.com>
>>Sent: Saturday, 16 February 2013, 20:06
>>Rebecca wrote:
>>> Sorry to chip in but
>>thank you for doing so, the more feedback we have the more
>>obvious the problems and solutions will be.
>>> I have been having trouble with add-ons in Ubuntu for ages -
>>> Hamish's response to Carla's email inspired me to try again,
>>> here's how far I get...
>>> First up specs:
>>> GRASS version:
 6.4.3RC2
>>> Platform: Linux-3.2.0-37-generic-pae-i686-with-Ubuntu-12.04-precise
>>So that I can replicate, what does 'dpkg -l grass' from a
>>Terminal window say about the exact package version?  (i.e. is
>>the package from ubuntugis or grass ppa or ...?) You may need
>>to pull the terminal window very wide to avoid the end of the
>>version number from being chopped off.
>>> I have the same error as Carla when installing through gui
>>> so switched to terminal.
>>(I think the problem with the wxGUI python version is something
>>to do with MODULE_TOPDIR; am looking into it)
>>> g.extension extension=r.out.kml svnurl=http://svn.osgeo.org
>>> /grass/grass-addons/grass6 prefix=/home/becca/.grass6/addons
>>> but this still ends in an error full export attached as txt
>>> file.
>>looking at the build log, it seems that
 the module was installed
>>ok, just that the `man` version of the help page failed to
>>install for some reason, but that is a minor inconvenience.
>>-> Try running it, does it work? Does 'locate r.out.kml' show it
>>in your addons dir?
>>Hamish
>_______________________________________________
>grass-user mailing list
>http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130217/a5972b1f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130217/a5972b1f/attachment-0001.png>
