[GRASS-user] Problem in install Extensions from addons
Rebecca Bennett
rabennett at ymail.com
Sun Feb 17 09:57:51 PST 2013
Hi Hamish, thanks for your response
dpkg -l grass
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Description
ii grass 6.4.3rc2-2~pre Geographic Resources Analysis Support System
Checked add-ons menu in gui no sign of r.out.kml, no response from typing command in gui but locate says it's there
GRASS 6.4.3RC2 (Deer_park):~ > locate r.out.kml
/home/becca/.grass6/addons/bin/docs/html/r.out.kml.html
/home/becca/.grass6/addons/bin/scripts/r.out.kml
/home/becca/.grass6/addons/docs/html/r.out.kml.html
/home/becca/.grass6/addons/scripts/r.out.kml
so I tried moving to the /home/becca/.grass6/addons/scripts/ and running (./r.out.kml) getting this message:
so close... :)
>________________________________
> From: Hamish <hamish_b at yahoo.com>
>To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>; Rebecca Bennett <rabennett at ymail.com>
>Sent: Saturday, 16 February 2013, 20:06
>Subject: Re: [GRASS-user] Problem in install Extensions from addons
>Rebecca wrote:
>> Sorry to chip in but
>thank you for doing so, the more feedback we have the more
>obvious the problems and solutions will be.
>> I have been having trouble with add-ons in Ubuntu for ages -
>> Hamish's response to Carla's email inspired me to try again,
>> here's how far I get...
>> First up specs:
>> GRASS version: 6.4.3RC2
>> Platform: Linux-3.2.0-37-generic-pae-i686-with-Ubuntu-12.04-precise
>So that I can replicate, what does 'dpkg -l grass' from a
>Terminal window say about the exact package version? (i.e. is
>the package from ubuntugis or grass ppa or ...?) You may need
>to pull the terminal window very wide to avoid the end of the
>version number from being chopped off.
>> I have the same error as Carla when installing through gui
>> so switched to terminal.
>(I think the problem with the wxGUI python version is something
>to do with MODULE_TOPDIR; am looking into it)
>> g.extension extension=r.out.kml svnurl=http://svn.osgeo.org
>> /grass/grass-addons/grass6 prefix=/home/becca/.grass6/addons
>> but this still ends in an error full export attached as txt
>> file.
>looking at the build log, it seems that the module was installed
>ok, just that the `man` version of the help page failed to
>install for some reason, but that is a minor inconvenience.
>-> Try running it, does it work? Does 'locate r.out.kml' show it
>in your addons dir?
>Hamish
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130217/a9431f47/attachment-0001.html>
