[GRASS-user] grass prompt default working directory
Vaclav Petras wenzeslaus at gmail.com
Wed Feb 27 00:06:16 PST 2013
Nikos, I have some related wiki-notes.
1) Maybe, it is not an easy task but I would prefer to have two pages,
one for "Writing Shell scripts" and one for "Using GRASS from Shell".
Now both is mixed in "GRASS and Shell" which, however, can be still
there to contain common things. What do you think?
2) Probably, we need a template "Main article: XXX". ...considering
the article "Working with GRASS without starting it explicitly" which
should be referenced also from "GRASS and Shell". (I added the link in
semi-wikipedia style, so you can see, if you like the style. The usage
of template on Wikipedia looks like this "{{main|Anonymous
function#C++}}".)
http://grasswiki.osgeo.org/wiki/GRASS_and_Shell#Automated_batch_jobs:_Setting_the_GRASS_environmental_variables
Vaclav
On 27 February 2013 08:20, Vincent Bain <bain at toraval.fr> wrote:
> Le mardi 26 février 2013 à 12:30 -0800, Hamish a écrit :
>> re. "and more", fwiw, I find adding this to ~/.inputrc is much
>> nicer to use than ^r,
>> # -------- Bind page up/down wih history search ---------
>> "\e[5~": history-search-backward
>> "\e[6~": history-search-forward
>> type the first few letters, then PgUp to see earlier matches..
> So nice !
> Thx a lot Hamish,
> Vincent
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
