[GRASS-user] problems running grass7 on Ubuntu 12.04
    Chad Ferguson
    terrafergus at gmail.com
    Wed Feb 27 10:33:05 PST 2013
I initially installed grass using the ppa, although I mistakenly used the
unstable ppa (as opposed to testing) so my first GRASS install was 6.x.
Upon noticing my error, I added the testing ppa and then had GRASS 6.x and
7.  I removed both from my system, as per Nikos suggestion, and reinstalled
using the apt-get update.
currently, this is what is returned in the terminal:
chad at chad-Satellite-S855:~$ grass70
/usr/bin/grass70: 25: exec: /usr/lib/grass70/etc/Init.sh: not found
thanks for the help
On Wed, Feb 27, 2013 at 1:07 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2013/2/27 Chad Ferguson <terrafergus at gmail.com>:
> > I did as you suggested.  Uninstalled, added the ppa and reinstalled but
> > unfortunately I am receiving the same error--
> >  /usr/lib/grass70/etc/Init.sh: No such file or directory
> huh, seems like that the package you installed is badly broken. GRASS
> 7 uses python script for initialization, not the shell script as GRASS
> 6. This is probably due the fact that the maintainer didn't used
> debian rules when building the package. Before providing such packages
> it should be fixed.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130227/09957913/attachment.html>
