[GRASS-user] Single grass window as attached display
SWAPAN GHOSH swap.ghsh at gmail.com
Tue Jan 8 02:53:59 PST 2013
*Dear Vaclav,*
Thank you very much for your good advice. I am trying to make it as single
window.
I have already see the link you send and found it suitable.
Actually, I am not Python developer. I am basically c\c++ developer for
console application. Here GUI is built by wxPython. So I have to learn the
wxPython.
Once, the problem is solved surely I share it with you and the grass-user
list.
*Thanks & Regards*
*Swapan*
On Tue, Jan 8, 2013 at 1:55 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi,
> this is more dev than user question since a lot of programming is
> needed. There are some wxGUI code refactoring efforts (code is
> published in grass 7, description will be published). One of long term
> goals of refactoring is to enable creation of one big window with lmgr
> and display. However, this refactoring is not finished and currently
> it is very hard to reuse wxGUI components/classes to build another
> GUI.
> I thing you have two possibilities:
> 1) Try to connect lmgr and display anyway. Maybe, it is possible to
> make it work for some task but the whole thing would be probably very
> buggy.
> 2) Build a new GUI from components/classes which are already prepared
> for reuse. There is a wxIClass (iclass, g.gui.iclass) module which
> reuses mapwindow (widget where a map i placed) and adds some very
> simple layer management (however, simple layer manager class is still
> missing). Depends on what you want, but maybe this is the way you want
> to go.
> Since this is a problem which is interesting for more people [1,2],
> please share your ideas and advances.
> Vaclav
> [1] http://grasswiki.osgeo.org/wiki/WxGUI#Layout
> [2] http://grasswiki.osgeo.org/wiki/GRASS_SoC_Ideas_2009#wxGUI
> On 8 January 2013 08:35, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> > Dear all,
> > Any body can help me for technical solution to change the current window
> for
> > grass gis 6.5 to attached display as layer manager and display window in
> a
> > single window.
> > Actually I  want to change this detached window for my own perpose.
> > Thank & Regards,
> > Swapan Ghosh
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130108/a7b56756/attachment.html>
