[GRASS-user] Using a variable inside GRASS commands with Python code/ grass.mapcalc
Brian Sanjeewa Rupasinghe
jinkabs at gmail.com
Tue Jan 8 04:45:24 PST 2013
Many thanks. It worked for me. Then i have a similar problem in
GRASS.mapcalc. What i need next is to add viewshed of each observer
location cumulatively while looping through the observer locations in order
to have final integrated viewshed analysis map. So i used the following
command in Python (some code ommitted)
for i in:
grass.run_command('r.viewshed', input = rinput, output = 'viewshed',
coordinate = [x,y], obs_elev = oelv, tgt_elev = th, memory = 4098, flags =
'b', overwrite = True, quiet = True)
grass.mapcalc("viewshed_cum = viewshed + viewshed_cum", overwrite =
True, quiet = True)
It seems that expressions like sum = c + sum does not work inside
grass.mapcalc.Is there any alternative or other way around to get this
done? I am using GRASS 7 in Windows 7.
Cheers, Brian
On Tue, Jan 8, 2013 at 1:25 PM, Anna Kratochvílová <kratochanna at gmail.com>wrote:
> Hi Brian,
> On Tue, Jan 8, 2013 at 6:51 AM, Brian Sanjeewa Rupasinghe
> <jinkabs at gmail.com> wrote:
> > Hi all
> > I am generating viewshed of each observer location by iterating through a
> > set of observer coordinate file through
> > Python code in Windows 7 . Below is the python command used in grass for
> > each iteration. According to this, each time
> > loop iterates, output is overwritten with the same name. Now what i need
> is
> > to keep each output of all the observer locations. For this, i need to
> > concatanate output name (i.e. 'viewshed' with loop index i which will be
> > 'viewshed' + str(i) ). How is that possible within
> > this grass.run_command?
> just set a variable within each loop and use it in the run_command:
> for i in ... :
> out = 'viewshed' + str(i)
> grass.run_command('r.viewshed', input = rinput, output = out, ...)
> Regards,
> Anna
> > Cheers, Brian
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130108/93f6da74/attachment.html>
