[GRASS-user] Single grass window as attached display
SWAPAN GHOSH
swap.ghsh at gmail.com
Sat Jan 12 11:08:29 PST 2013
I am trying to change the grass wxgui. I got this error by interupting the
grass run as when I press the start grass button it automatically quit.
I would not like to create new extend gui as this is time consuming.
Alternatively I have to do that as you told by swithing from init.bat to my
new gui.
Thnks & Rgd
Swapan
On Jan 12, 2013 4:02 PM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> On 11 January 2013 13:21, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>> Please see the error when start bhoomi(Grass).
>> [image: Inline image 1]
> Hi, I don't understand in which circumstances are you running grass.
> However, (Python exception) KeyboardInterrupt would mean, in Unix command
> line, that you pressed Ctrl+C in order to interrupt the program.
> BTW, for the development of any grass GUI I would suggest you to develop
> keep it separate from g.gui (wxgui.py) command (which is called by
> init.bat) and start your new application separately from command line (as a
> python script, i.e. "python path/to/my/app.py" or as a grass module as
> g.gui.* modules do).
>> Thanks & Regards,
>> Swapan
>> On Fri, Jan 11, 2013 at 5:43 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>> what error you are getting?
>>> On Fri, Jan 11, 2013 at 4:44 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>>> *Dear Rashad,*
>>>> * *As per your attachment I have change the entire program. But then
>>>> grass will not start.
>>>> Please give me a out line how to deploy this program change.
>>>> *Thanks & Regards,*
>>>> *Swapan*
>>>> On Wed, Jan 9, 2013 at 5:59 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>>>> try this attachment
>>>>> On Wed, Jan 9, 2013 at 5:37 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>>>>> *Dear Rashad,*
>>>>>> Can you please send me the wxPython folder by making it
>>>>>> as wxPython.rar and any other related doc from your local copy.
>>>>>> This lay out is my exact requirement. And which version of python you
>>>>>> used.
>>>>>> I am waiting for kind help.
>>>>>> *Thanks & Regards,*
>>>>>> *Swapan*
>>>>>> On Tue, Jan 8, 2013 at 4:31 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>>>>>>> you may give a look at DataCatalog[1]. code is very old. I have some
>>>>>>> changes in my local copy. But didnt get time to push to addons. The idea is
>>>>>>> pretty much same and it can also communicate with ossim using planetSasha.
>>>>>>> Unfortunately work is incomplete :(
>>>>>>> [1]
>>>>>>> http://svn.osgeo.org/grass/grass-addons/grass6/gui/wxpython/wx.data_catalog/
>>>>>>> [2]
>>>>>>> http://www.geofemengineering.it/GeofemEngineering/Blog/Voci/2009/12/13_Planet_-_Sasha.html
>>>>>>> On Tue, Jan 8, 2013 at 4:23 PM, SWAPAN GHOSH <swap.ghsh at gmail.com>wrote:
>>>>>>>> *Dear Vaclav,*
>>>>>>>> Thank you very much for your good advice. I am trying to make it as
>>>>>>>> single window.
>>>>>>>> I have already see the link you send and found it suitable.
>>>>>>>> Actually, I am not Python developer. I am basically c\c++ developer
>>>>>>>> for console application. Here GUI is built by wxPython. So I have to learn
>>>>>>>> the wxPython.
>>>>>>>> Once, the problem is solved surely I share it with you and the
>>>>>>>> grass-user list.
>>>>>>>> *Thanks & Regards*
>>>>>>>> *Swapan*
>>>>>>>> On Tue, Jan 8, 2013 at 1:55 PM, Vaclav Petras <wenzeslaus at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> Hi,
>>>>>>>>> this is more dev than user question since a lot of programming is
>>>>>>>>> needed. There are some wxGUI code refactoring efforts (code is
>>>>>>>>> published in grass 7, description will be published). One of long
>>>>>>>>> term
>>>>>>>>> goals of refactoring is to enable creation of one big window with
>>>>>>>>> lmgr
>>>>>>>>> and display. However, this refactoring is not finished and
>>>>>>>>> currently
>>>>>>>>> it is very hard to reuse wxGUI components/classes to build another
>>>>>>>>> GUI.
>>>>>>>>> I thing you have two possibilities:
>>>>>>>>> 1) Try to connect lmgr and display anyway. Maybe, it is possible to
>>>>>>>>> make it work for some task but the whole thing would be probably
>>>>>>>>> very
>>>>>>>>> buggy.
>>>>>>>>> 2) Build a new GUI from components/classes which are already
>>>>>>>>> prepared
>>>>>>>>> for reuse. There is a wxIClass (iclass, g.gui.iclass) module which
>>>>>>>>> reuses mapwindow (widget where a map i placed) and adds some very
>>>>>>>>> simple layer management (however, simple layer manager class is
>>>>>>>>> still
>>>>>>>>> missing). Depends on what you want, but maybe this is the way you
>>>>>>>>> want
>>>>>>>>> to go.
>>>>>>>>> Since this is a problem which is interesting for more people [1,2],
>>>>>>>>> please share your ideas and advances.
>>>>>>>>> Vaclav
>>>>>>>>> [1] http://grasswiki.osgeo.org/wiki/WxGUI#Layout
>>>>>>>>> [2] http://grasswiki.osgeo.org/wiki/GRASS_SoC_Ideas_2009#wxGUI
>>>>>>>>> On 8 January 2013 08:35, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>>>>>>>>> > Dear all,
>>>>>>>>> > Any body can help me for technical solution to change the
>>>>>>>>> current window for
>>>>>>>>> > grass gis 6.5 to attached display as layer manager and display
>>>>>>>>> window in a
>>>>>>>>> > single window.
>>>>>>>>> > Actually I want to change this detached window for my own
>>>>>>>>> perpose.
>>>>>>>>> > Thank & Regards,
>>>>>>>>> > Swapan Ghosh
>>>>>>>>> > _______________________________________________
>>>>>>>>> > grass-user mailing list
>>>>>>>>> > grass-user at lists.osgeo.org
>>>>>>>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>>>> Regards,
>>>>>>> Rashad
>>>>> Regards,
>>>>> Rashad
>>> Regards,
>>> Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130113/889c3a74/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130113/889c3a74/attachment-0001.png>
