[GRASS-user] Single grass window as attached display
SWAPAN GHOSH
swap.ghsh at gmail.com
Wed Jan 9 04:07:16 PST 2013
*Dear Rashad,*
Can you please send me the wxPython folder by making it as wxPython.rar and
any other related doc from your local copy.
This lay out is my exact requirement. And which version of python you used.
I am waiting for kind help.
*Thanks & Regards,*
*Swapan*
On Tue, Jan 8, 2013 at 4:31 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> you may give a look at DataCatalog[1]. code is very old. I have some
> changes in my local copy. But didnt get time to push to addons. The idea is
> pretty much same and it can also communicate with ossim using planetSasha.
> Unfortunately work is incomplete :(
> [1]
> http://svn.osgeo.org/grass/grass-addons/grass6/gui/wxpython/wx.data_catalog/
> [2]
> http://www.geofemengineering.it/GeofemEngineering/Blog/Voci/2009/12/13_Planet_-_Sasha.html
> On Tue, Jan 8, 2013 at 4:23 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>> *Dear Vaclav,*
>> Thank you very much for your good advice. I am trying to make it as
>> single window.
>> I have already see the link you send and found it suitable.
>> Actually, I am not Python developer. I am basically c\c++ developer for
>> console application. Here GUI is built by wxPython. So I have to learn the
>> wxPython.
>> Once, the problem is solved surely I share it with you and the grass-user
>> list.
>> *Thanks & Regards*
>> *Swapan*
>> On Tue, Jan 8, 2013 at 1:55 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>>> Hi,
>>> this is more dev than user question since a lot of programming is
>>> needed. There are some wxGUI code refactoring efforts (code is
>>> published in grass 7, description will be published). One of long term
>>> goals of refactoring is to enable creation of one big window with lmgr
>>> and display. However, this refactoring is not finished and currently
>>> it is very hard to reuse wxGUI components/classes to build another
>>> GUI.
>>> I thing you have two possibilities:
>>> 1) Try to connect lmgr and display anyway. Maybe, it is possible to
>>> make it work for some task but the whole thing would be probably very
>>> buggy.
>>> 2) Build a new GUI from components/classes which are already prepared
>>> for reuse. There is a wxIClass (iclass, g.gui.iclass) module which
>>> reuses mapwindow (widget where a map i placed) and adds some very
>>> simple layer management (however, simple layer manager class is still
>>> missing). Depends on what you want, but maybe this is the way you want
>>> to go.
>>> Since this is a problem which is interesting for more people [1,2],
>>> please share your ideas and advances.
>>> Vaclav
>>> [1] http://grasswiki.osgeo.org/wiki/WxGUI#Layout
>>> [2] http://grasswiki.osgeo.org/wiki/GRASS_SoC_Ideas_2009#wxGUI
>>> On 8 January 2013 08:35, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>>> > Dear all,
>>> > Any body can help me for technical solution to change the current
>>> window for
>>> > grass gis 6.5 to attached display as layer manager and display window
>>> in a
>>> > single window.
>>> > Actually I want to change this detached window for my own perpose.
>>> > Thank & Regards,
>>> > Swapan Ghosh
>>> > _______________________________________________
>>> > grass-user mailing list
>>> > grass-user at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Regards,
> Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130109/ff5f1e06/attachment.html>
