[GRASS-user] Single grass window as attached display
Rashad M mohammedrashadkm at gmail.com
Wed Jan 9 04:29:34 PST 2013
try this attachment
On Wed, Jan 9, 2013 at 5:37 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
> *Dear Rashad,*
> Can you please send me the wxPython folder by making it as wxPython.rar
> and any other related doc from your local copy.
> This lay out is my exact requirement. And which version of python you used.
> I am waiting for kind help.
> *Thanks & Regards,*
> *Swapan*
> On Tue, Jan 8, 2013 at 4:31 PM, Rashad M <mohammedrashadkm at gmail.com>wrote:
>> you may give a look at DataCatalog[1]. code is very old. I have some
>> changes in my local copy. But didnt get time to push to addons. The idea is
>> pretty much same and it can also communicate with ossim using planetSasha.
>> Unfortunately work is incomplete :(
>> [1]
>> http://svn.osgeo.org/grass/grass-addons/grass6/gui/wxpython/wx.data_catalog/
>> [2]
>> http://www.geofemengineering.it/GeofemEngineering/Blog/Voci/2009/12/13_Planet_-_Sasha.html
>> On Tue, Jan 8, 2013 at 4:23 PM, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>>> *Dear Vaclav,*
>>> Thank you very much for your good advice. I am trying to make it as
>>> single window.
>>> I have already see the link you send and found it suitable.
>>> Actually, I am not Python developer. I am basically c\c++ developer for
>>> console application. Here GUI is built by wxPython. So I have to learn the
>>> wxPython.
>>> Once, the problem is solved surely I share it with you and the
>>> grass-user list.
>>> *Thanks & Regards*
>>> *Swapan*
>>> On Tue, Jan 8, 2013 at 1:55 PM, Vaclav Petras <wenzeslaus at gmail.com>wrote:
>>>> Hi,
>>>> this is more dev than user question since a lot of programming is
>>>> needed. There are some wxGUI code refactoring efforts (code is
>>>> published in grass 7, description will be published). One of long term
>>>> goals of refactoring is to enable creation of one big window with lmgr
>>>> and display. However, this refactoring is not finished and currently
>>>> it is very hard to reuse wxGUI components/classes to build another
>>>> GUI.
>>>> I thing you have two possibilities:
>>>> 1) Try to connect lmgr and display anyway. Maybe, it is possible to
>>>> make it work for some task but the whole thing would be probably very
>>>> buggy.
>>>> 2) Build a new GUI from components/classes which are already prepared
>>>> for reuse. There is a wxIClass (iclass, g.gui.iclass) module which
>>>> reuses mapwindow (widget where a map i placed) and adds some very
>>>> simple layer management (however, simple layer manager class is still
>>>> missing). Depends on what you want, but maybe this is the way you want
>>>> to go.
>>>> Since this is a problem which is interesting for more people [1,2],
>>>> please share your ideas and advances.
>>>> Vaclav
>>>> [1] http://grasswiki.osgeo.org/wiki/WxGUI#Layout
>>>> [2] http://grasswiki.osgeo.org/wiki/GRASS_SoC_Ideas_2009#wxGUI
>>>> On 8 January 2013 08:35, SWAPAN GHOSH <swap.ghsh at gmail.com> wrote:
>>>> > Dear all,
>>>> > Any body can help me for technical solution to change the current
>>>> window for
>>>> > grass gis 6.5 to attached display as layer manager and display window
>>>> in a
>>>> > single window.
>>>> > Actually I  want to change this detached window for my own perpose.
>>>> > Thank & Regards,
>>>> > Swapan Ghosh
>>>> > _______________________________________________
>>>> > grass-user mailing list
>>>> > grass-user at lists.osgeo.org
>>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>> Regards,
>>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130109/e5237dda/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130109/e5237dda/attachment-0002.bin>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130109/e5237dda/attachment-0003.bin>
