[GRASS-user] Use of g.mlist inside r.series
Brian Sanjeewa Rupasinghe jinkabs at gmail.com
Thu Jan 10 05:32:10 PST 2013
Many Thanks Martin. It worked fine.
Cheers, Brian
On Thu, Jan 10, 2013 at 6:55 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2013/1/10 Brian Sanjeewa Rupasinghe <jinkabs at gmail.com>:
> > grass.run_command ("r.series", input="`g.mlist pattern = 'viewshed*' sep
> > `", output = 'xx', method = 'sum')
> you cannot use bash-like constructions in Python script. Try
> maps = grass.mlist_strings(type = 'rast', pattern = 'viewshed*')
> grass.run_command ("r.series", input = maps, output = 'xx', method = 'sum')
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130110/b7aed85f/attachment.html>
