[GRASS-user] Exporting GRASS vector to ShapeFile
Maris Nartiss maris.gis at gmail.com
Fri Jan 11 09:58:11 PST 2013
Try to run on Your vector dataset:
v.category option=add type=centroid
Then export with v.out.ogr.
Reason - v.out.ogr is working correctly and Your centroids have no
CATs and thus are not exported. That would explain "not correctly
created" - an empty shapefile.
Hope it helps,
Maris.
2013/1/11 Brian Sanjeewa Rupasinghe <jinkabs at gmail.com>:
> Hi,
> I am using GRASS 7svn in windows. Using v.out.ogr function in GRASS i
> converted a set of polygons (some of which have holes as well) into a shape
> file.
> However, when i do not tick the box in Selection pane: ‘Also export features
> without category (not labelled) otherwise only features with category are
> exported,
> the function keeps on executing and shapefile is not correctly created. When
> i tick this, the shapefile is created but filling all holes as separate
> polygons. Any comment on this behaviour?
> Cheers, Brian.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
