[GRASS-user] Exporting GRASS vector to ShapeFile
Brian Sanjeewa Rupasinghe
jinkabs at gmail.com
Fri Jan 11 21:53:36 PST 2013
I used v.category. But it too keeps on running failing to add categories.
On Fri, Jan 11, 2013 at 11:28 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
> Try to run on Your vector dataset:
> v.category option=add type=centroid
> Then export with v.out.ogr.
> Reason - v.out.ogr is working correctly and Your centroids have no
> CATs and thus are not exported. That would explain "not correctly
> created" - an empty shapefile.
> Hope it helps,
> Maris.
> 2013/1/11 Brian Sanjeewa Rupasinghe <jinkabs at gmail.com>:
> > Hi,
> > I am using GRASS 7svn in windows. Using v.out.ogr function in GRASS i
> > converted a set of polygons (some of which have holes as well) into a
> shape
> > file.
> > However, when i do not tick the box in Selection pane: ‘Also export
> features
> > without category (not labelled) otherwise only features with category are
> > exported,
> > the function keeps on executing and shapefile is not correctly created.
> When
> > i tick this, the shapefile is created but filling all holes as separate
> > polygons. Any comment on this behaviour?
> > Cheers, Brian.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130112/76c52134/attachment.html>
