[GRASS-user] Exporting GRASS vector to ShapeFile
Maris Nartiss
maris.gis at gmail.com
Fri Jan 11 23:22:15 PST 2013
Please, post output of v.build
2013/1/12 Brian Sanjeewa Rupasinghe <jinkabs at gmail.com>:
> Hi,
> I used v.category. But it too keeps on running failing to add categories.
> On Fri, Jan 11, 2013 at 11:28 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Try to run on Your vector dataset:
>> v.category option=add type=centroid
>> Then export with v.out.ogr.
>> Reason - v.out.ogr is working correctly and Your centroids have no
>> CATs and thus are not exported. That would explain "not correctly
>> created" - an empty shapefile.
>> Hope it helps,
>> Maris.
>> 2013/1/11 Brian Sanjeewa Rupasinghe <jinkabs at gmail.com>:
>> > Hi,
>> > I am using GRASS 7svn in windows. Using v.out.ogr function in GRASS i
>> > converted a set of polygons (some of which have holes as well) into a
>> > shape
>> > file.
>> > However, when i do not tick the box in Selection pane: ‘Also export
>> > features
>> > without category (not labelled) otherwise only features with category
>> > are
>> > exported,
>> > the function keeps on executing and shapefile is not correctly created.
>> > When
>> > i tick this, the shapefile is created but filling all holes as separate
>> > polygons. Any comment on this behaviour?
>> > Cheers, Brian.
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
