[GRASS-user] Exporting GRASS vector to ShapeFile
Maris Nartiss
maris.gis at gmail.com
Sun Jan 13 00:46:59 PST 2013
According to v.build output, when exporting areas, You should get 64
closed area features with some holes. Please double check Your
v.out.ogr parameters and output of v.category.
Maris.
2013/1/12 Brian Sanjeewa Rupasinghe <jinkabs at gmail.com>:
> Hi Maris, Thanks. Please see following the build info of the Grass Vector
> file that i need to convert to a shapefile.
> Cheers, Brian.
> (Sat Jan 12 14:25:02 2013)
> v.build map=MaskVector at user1
> Building topology for vector map <MaskVector at user1>...
> Registering primitives...
> 184 primitives registered
> 4948 vertices registered
> Building areas...
> 110 areas built
> 91 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 101
> Number of primitives: 184
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 120
> Number of centroids: 64
> Number of areas: 110
> Number of isles: 91
> (Sat Jan 12 14:25:02 2013) Command finished (0 sec)
> On Sat, Jan 12, 2013 at 12:52 PM, Maris Nartiss <maris.gis at gmail.com> wrote:
>> Please, post output of v.build
>> > Hi,
>> > I used v.category. But it too keeps on running failing to add
>> > categories.
>> > On Fri, Jan 11, 2013 at 11:28 PM, Maris Nartiss <maris.gis at gmail.com>
>> > wrote:
>> >> Try to run on Your vector dataset:
>> >> v.category option=add type=centroid
>> >> Then export with v.out.ogr.
>> >> Reason - v.out.ogr is working correctly and Your centroids have no
>> >> CATs and thus are not exported. That would explain "not correctly
>> >> created" - an empty shapefile.
>> >> Hope it helps,
>> >> Maris.
>> >> 2013/1/11 Brian Sanjeewa Rupasinghe <jinkabs at gmail.com>:
>> >> > Hi,
>> >> > I am using GRASS 7svn in windows. Using v.out.ogr function in GRASS i
>> >> > converted a set of polygons (some of which have holes as well) into a
>> >> > shape
>> >> > file.
>> >> > However, when i do not tick the box in Selection pane: ‘Also export
>> >> > features
>> >> > without category (not labelled) otherwise only features with category
>> >> > are
>> >> > exported,
>> >> > the function keeps on executing and shapefile is not correctly
>> >> > created.
>> >> > When
>> >> > i tick this, the shapefile is created but filling all holes as
>> >> > separate
>> >> > polygons. Any comment on this behaviour?
>> >> > Cheers, Brian.
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > grass-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
