[GRASS-user] Interpolation with v.surf.rst
Brian Sanjeewa Rupasinghe
jinkabs at gmail.com
Wed Jan 16 01:16:34 PST 2013
I have 2D isolines in GRASS vector format with elevation in an attribute
field called height.
I used v.surf.rst function to create raster DEM. However, after creation,
it outputs a DEM
with value 0 elevation only. The description of the function is given as
below. What would
be the possible cause for this? I am using wingrass 7.
cheers, Brian.
v.surf.rst -z input=isoline at TOPOIKDATA zcolumn=height elev=elev_1m
Reading features from vector map ...
Ignoring 86730 points (too dense)
Processing segments...
WARNING: Taking too long to find points for interpolation - please change
the region to area where your points are. Continuing calculations...
v.surf.rst complete.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130116/3276512c/attachment.html>
