[GRASS-user] Problem in v.surf.rst
Brian Sanjeewa Rupasinghe jinkabs at gmail.com
Thu Jan 17 19:48:37 PST 2013
As i mentioned in my couple of previous mails, I found that v.surf.rst
function does not work
for either 2D point or iso-lines unless "Use Z coordinates for
approximation" flag is ticked
together with the selection of the *name* of the attribute column with
values to be used for
approximation. When both are chosen, it runs and gives the expected
output.However
I think there is a minor bug in this function and it should be rectified
and made work for
2D data sets without selection of Z flag. The version of GRASS i used is
WINGRASS 7
installed through OSGEO4W installer.
Cheers, Brian.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130118/4ad66c8e/attachment.html>
