[GRASS-user] Loss of data using v.net
דור פרידמן
dof1985 at gmail.com
Wed Jan 23 11:22:24 PST 2013
I'm trying to build a network in GRASS in order to find the shortest path
from any settlement out of 1120 (points), to one waste treatment facility
out of 27 (points). I plan to use v.net.distance which is designated to
this purpose, and to define source and destination points using a column
called "type". In that column I have assigned the settlements layer with
the number 5 and the treatment facilities with 1.
My problem occurs when I try to create the network using v.net; If I define
nodes layer (nlayer=2) to be 2, I lose all the points and can't find it,
even by using v.extract. Otherwise (when nlayer=1) the attributes
describing type are being auromatically changed to 4, which is the type
attribute for roads.
Since I have 1120 I find that using from_cat instead of a SQL restriction
will be too hard.
Any one has an idea why I'm losing this crucial data and how can I prevent
it from happening?
Thanks in advanced,
Dor
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130123/e611fde8/attachment.html>
