[GRASS-user] error: accumulation map does not match with	elevation map!
    Giuliano Urgeghe
    giuliano.u at gmail.com
    Tue Jan 29 06:39:54 PST 2013
I wanted to inform you that the error is upstream of r.thin because r.thin
works on a map that has this metadata:
Layer:    LuLitarroni61_dem_stream_e at ag  Date: Tue Jan 29 15:19:45 2013    |
 | Mapset:   aglientu                       Login of Creator: giuliano
 | DataBase: /home/giuliano/Scrivania/grass
 | Title:     ( tmp )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    CELL
 |   Rows:         2426
 |   Columns:      3003
 |   Total Cells:  7285278
 |        Projection: Transverse Mercator
 |            N: 4561913.0845    S: 4537653.0845   Res:    10
 |            E: 1528979.264    W: 1498949.264   Res:    10
 |   Range of data:    min = NULL  max = NULL
 |   Data Description:
 |    generated by r.mapcalc
 |   Comments:
 |    LuLitarroni61_dem_stream_e * LuLitarroni61_dem_mask
View this message in context: http://osgeo-org.1560.n6.nabble.com/error-accumulation-map-does-not-match-with-elevation-map-tp5029128p5030631.html
Sent from the Grass - Users mailing list archive at Nabble.com.
